Has anyone ever snuck the cam seal out and in without pulling the entire front dress apart on a B230FT?
I just did the timing belt and seals 1k ago and the wonderful elring cam seal I used after reading allllll those posts about only use elring....is leaking. PCV maintenance already done. Temp catch can caught only minimal oil residue, mostly condensate. Thanks.
Cam seal replacement without removing t belt?
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
Don't use the orange Elring seals - only use OEM Genuine Volvo. Elring makes pretty good gaskets and such, but they just don't size the front oil seals correctly..
You can pull the cam seal out without pulling any of the lower end stuff. Pop off the upper timing belt cover. Turn the crank gear to get the engine to TDC. Loosen the tensioner, pull the belt off the cam gear, and clamp it somewhere out of the way - make sure it is pulled taught so nothing turns while you're working on the cam seal. Optimally, use some sort of plastic clamp so you don't damage the belt (or vice grips with a soft towel between the jagged jaws and the belt). Pull the cam gear and replace the seal. Make sure that the cam is at TDC when you pop the belt back on.
Hopefully that has enough info to get you going, unlike those shoddy Haynes manuals.
"How to replace engine: Remove engine. Install is reverse of removal."
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I like that Haynes reference.mtd240 wrote:Don't use the orange Elring seals - only use OEM Genuine Volvo. Elring makes pretty good gaskets and such, but they just don't size the front oil seals correctly..
1988 Volvo 760 Turbo Wagon
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
lummert is right.
Pointer on installing seals: when setting the new seal, use a piece of PVC pipe to ensure even pressure when putting it in. Make sure it's lightly oiled on the contact side. Set it 1-2mm in from flush. If it goes in too far, oil will blow right past it.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- 1268 Views
Last post by oragex
- 9693 Views
Last post by tyguyc
- 2055 Views
Last post by wizechatmgr
- 582 Views
- 19 Replies
- 5495 Views
