2000 V70 XC crack in cat
Exhaust Leak At Catalytic Convertor - Buy New or Weld?
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
While under the car with it running I heard the ringing of a exhaust leak coming from the cat. I cut the protective shield shield so I could pull it out of the way. There was a crack/hole in the center where the rivet is seated. Ground off rust and welded in a sheet of stock to seal off the leak. Beats buying a new cat. It is so nice to have a neighbor with a lift and welder.
- Crack at rivet
- image.jpeg (247.63 KiB) Viewed 2317 times
- Heat shield cut free
- image.jpeg (311.36 KiB) Viewed 2317 times
- Stock sheet metal
- image.jpeg (175.68 KiB) Viewed 2317 times
- Tacked sheet first then filled in
- image.jpeg (203.03 KiB) Viewed 2317 times
- Done
- image.jpeg (280.54 KiB) Viewed 2317 times
- 57gretsch
- Year and Model: 2005 XC90 T6
- Been thanked: 2 times
Just did the same thing on Monday. Also welded up the joint closest to the manifold. I was told that I needed a new cat when I took the car in for a safety. After pricing them out I decided to have a look myself. Won't be going back to that station anytime soon for opinions or work.
No good deed ever goes unpunished.
1997 855 T5, 2000 V70XC, 1998 V70 AWD Manual, 2007 XC70
- Has thanked: 2197 times
- Been thanked: 1851 times
Nice job guys!
- Been thanked: 4064 times
Nice 1000 USD save. Relieved to find this wasn't about drug smuggling in pets, too.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
How long do you expect the weld patch to last? I've got a mildly leaking muffler (crack near pipe attachment), which I'm considering just replacing. Mostly, I don't want to have to patch it every 3-4 months, which is about how long weld patches would last on my 1990 240's exhaust system before I replaced the whole thing.
Great pics, thanks.
Great pics, thanks.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
JDS60R
- Been thanked: 3 times
When I lived in MA we would get 2 years from a steel patch and an almost permanent fix from stainless. I know Volvo used 400 series stainless for some of the cats but that rust shouldn't be that bad on 400.
If you need a cat you can run a magnaflow 51356 if it needs a center bung or a 51206 if you don't. If its a 98 or similar you can run a 99065HM Either way you will need a 45 degree bend to remake the turn between the flex joint and the new cat. (Many volvo cats are 20 inches long while most aftermarket cats are 11 to 15 in long).
Part numbers above are for federal emissions . If you need CA or NY call Magnaflow and they will tell you equivalent.
Some require a bung in the 45 degree section (98 and similar) so pick up a bung while shopping. I tig in with 309L rod . expect to pay $30 for the 45 bend, $100 for a magnaflow cat and $10 for a bung.
Magnaflow also has the entire downpipe but its $500 http://www.magnaflow.com/products?partNumber=24071
http://www.magnaflow.com/products?partNumber=99065HM
http://www.magnaflow.com/products?partN ... Term=51356
http://www.magnaflow.com/products?partN ... Term=51206
Sorry if this sounds like a Magnflow commercial. Its just the brand I use. They don't give me a problem with codes etc ,so I'll continue to use them.
Retired
- 679 Views
Last post by v70XCSteve
- 2034 Views
Last post by polskamafia mjl
- 2241 Views
Last post by db130
- 1916 Views
Last post by ta79pr
- 1172 Views
Last post by MadeInJapan
