raised dipstick = more power?
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
Yeah, weird.. I accidentally drove my car with the dipstick not pushed all the way in, and it has more power. Well, the boost came on quicker, definitely livelier. I haven't a clue if this is normal or a symptom of a problem, but there it is.. Comments?
BTW, I drove an 800 mile Round trip with the new planar front 02 sensor, and got 25mpg on a car with about 230,000 miles.. Not bad...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Did you have oil spray everywhere? More power and oil everywhere would make me think you'r PCV is so clogged that the engine has a lot of pressure its fighting.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
polskamafia mjl wrote:Did you have oil spray everywhere? More power and oil everywhere would make me think you'r PCV is so clogged that the engine has a lot of pressure its fighting.
Yeah, I think you're right.
Check your PCV, I bet it's clogged!
azureblue
Post by azureblue »
Probably it - I had too much CC pressure and thought it was the PTC (?) valve in the intake manifold by the turbo. I cleaned it and the oil loss through the rear main seal went down. But there's not much oil spray at all.. I'll check for pressure in a couple of days...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Raised dipstick = More Power = Clogged PCV.
No question about it.
Search forum for PCV overhaul, a lot of threads on it.
azureblue
Post by azureblue »
I figured I'd have to do it. The system was redone about 6 years ago by a shop, so I will assume the can can be cleaned out and reused. I'm also going to do the bigger hose mod, too. Thanks for the input..
On the other topic, I think upgrading to a planar O2 sensor is worth it. I posted about it a month or so ago, but the splicing kit- with the official Bosch splicing block, comes with a sensor that has plenty of cable to reach the connector, so putting new connector pins on the new cable is a better way of doing the job. But the connector block works fine - it's just fiddly to put together.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
