S60 check valve direction
WTF
Year and Model: 2003 s60 turbo
Post by WTF »
My son took apart everything 2003 s60 turbo, AWD, I can't figure out what way the gray check valves go. This was not easy replacing the pcv system, everything was clogged. It runs now after blowing off huge clouds of smoke which I'm hoping were residual. I know a diagram is under the hood but it doesn't show the arrow directions on either valve.
What is the best method to check the check valves are in correctly?
I replaced all tubing and left them accessible.
Has thanked: 1610 times
Been thanked: 4065 times
Can you put up a picture of your sticker and we can annotate the check valve directions.??
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
As a general rule arrows point to the intake manifold.
