Replaced the last three original coils and plugs on my NA
Tools: torx 30 for cover screws, M6 for coil screws, small screwdriver , plug lube, plug socket 5/8 with insert, long extension
Notes
Cover screws obstructed by the cross brace. A wobble might be useful to remove cover
The m6 coil screws ground the high tension coil, so they must be clean And tight.
I used a small screw driver to open the electrical connector snap all the way. Careful if you do this .
Plugs looked ok, replaced as unknown mileage
2005 v70 NA coils and plugs
Canadian Moose
- Year and Model: 2002 V70
Are those double electrode plugs OEM Volvo? Did they do that for reliability in case one electrode fails you have a backup?
- Has thanked: 2856 times
- Been thanked: 1332 times
Something's missing.
Give the focus knob a twist, or run a deconvolution on it
JRL
- Year and Model: Several
- Been thanked: 16 times
NA's use DENSO pronged plugsCanadian Moose wrote:Are those double electrode plugs OEM Volvo? Did they do that for reliability in case one electrode fails you have a backup?
Canadian Moose
I am surprised that OEM would run those. I always thought that single electrode plugs were the best. Electricity goes the path of least resistance so single electrode makes sense to me.
- 5967 Views
Last post by chrism
- 1712 Views
Last post by FLXC90
- 1872 Views
Last post by RickHaleParker
- 2235 Views
Last post by MoVolvos
- 1539 Views
Last post by Metallo
