2004 XC90 - ECM DTC SET
jbarrow8081
Year and Model: 2004 xc90
Post by jbarrow8081 »
Good Morning All,
I have a 2004 xc90 with about 135,000 miles. My check engine light came on and I checked the codes quickly and found that the ECM DTC seems to be the culpret. I am an AVERAGE mechanic at best but I am wondering does this typically mean the entire ECM module needs to be replaced or is this normally something else. I am guessing the answer is that it could be anything and I should have a proper mechanic look at it. I am just trying to get more information before I go in. Any suggestions/thoughts are appreciated.
Thanks!
Joe
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
ECM DTC is broad enough to warranty a separate topic on it's own but the first thing you might try is to get any reasonable OBD reader on the car and see if it reports a more specific (like a P-something) code. Then you can try and correlate that code to a Volvo code via another thread like http://forums.swedespeed.com/showthread ... rsion-List (not my link, just passing on, may not be 100% accurate but close enough).
To read the Volvo code you need a DICE and VIDA (can look "VIDA/DICE" up if you want, lot of info for what it does) although I am aware of other more advanced OBD readers that can display these as well.
Good luck!
Has thanked: 1610 times
Been thanked: 4065 times
As you can tell from my sig, ECU problems are rarer than henways teeth.
Most ECM fault codes refer to a component fault detected by the ECU, Not an actual ECU problem
