V70 suspension sequence
woodycaldercloggs
- Year and Model: v70 1998
- Has thanked: 23 times
I have a 1997 Volvo V70 turbo and intend to change the struts, control arms, outer tie rods and control links this weekend. Does anyone know the best and easiest sequence in which to do this work?
woodycaldercloggs
There is no vertical play in the wheels and the boots seem ok.
Is there any preferred sequence when doing these jobs?
- Has thanked: 311 times
- Been thanked: 817 times
You don't want the control arm and the strut to both be off at the same time, or the big steering knuckle will flop around too much. Here's the sequence I would use:
(0) Try to break free the cinch nut on tie rod. Soak with quality penetrant, use heat, get it broken loose in advance then re-tighten it.
(1) Old strut out, new strut in, but do not reconnect the sway bar end link when you are reinstalling.
(2) Remove old end link
(3) Remove and replace tie rod(s)
(4) Remove and replace control arm (drop at subframe first, then open at pinch bolt to remove completely)
(5) Install new end link
You can do all of this without removing the brake caliper, I know I would, but you may want to take it off and secure it to the coil spring to get it out of the way.
woodycaldercloggs
That all sounds pretty good.
Many thanks
Many thanks
- 1585 Views
Last post by dosbricks
- 11 Replies
- 4720 Views
- 1707 Views
Last post by wizechatmgr
- 1705 Views
Last post by raivis_rsn
- 1260 Views
Last post by Archer
