'95 850 No power
Kuhnboy
Year and Model: 1995 850
Post by Kuhnboy »
Hello all, I recently bought my first Volvo. It's a 1995 850 turbo sedan and I'm having a hard time figuring this out. It will run and rev fine in park and neutral, but won't have any power when I give it more than like 1/10th throttle. It's showing boost on the gauge, it has a new fuel pump and filter, and new cat. I've heard it could be the old cat blew out and clogged the muffler, it might have low fuel pressure, and the wastegate might have a problem. It sounds great when it's just idling or in park, but won't accelerate above thirty mph on its own. Any help or tips on where to start would be amazing. Thank you in advance.
Has thanked: 1610 times
Been thanked: 4068 times
I takes about 1/2 HP to rev an engine and make it sound fine.
Extracting the 200 HP you need to get your car and up and going is a different beast.
test your fuel pressure at the rail on start and revving
New cap rotor plugs wires coil?
compression test is final answer.
Oh yeah -if you get boost when you rev at idle, something is wrong. How much are you seeing - or are you using the gauge installed by marketing ??
:lol:
Kuhnboy
Post by Kuhnboy »
It's showing boost when driving, I'm thinking now that it's the tps. I don't know if the last owner replaced any ignition parts. I'm going to be testing the fuel pressure later, if I can scan it and the tps isn't working how it should
Kuhnboy
Post by Kuhnboy »
Just got a hold of a fuel pressure gauge and it's reading nineteen when running... The PO gave me receipts with the car, including one for a fuel pump and filter two months ago. Could this be the regulator?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
You need 43.5psi at first prime before starting the engine.
At idle you must have around 35psi.
And again...at full throttle at high rpm you need 43.5psi.
19psi is too low even at idle.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Kuhnboy
Post by Kuhnboy »
19 is all it will get and when it's not running it will immediately drop to 10 psi. Any ideas on what this could be?
misha
Post by misha »
What brand is fuel pump?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Kuhnboy
Post by Kuhnboy »
I'm not sure on the brand, it was 165.00$ for just the pump. Will it say in a place I can see without dropping the tank?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
where was the pump purchased? vendor x price may reveal brand. otherwise it would be on the side of the pump motor (in the tank)
you should have access to the pump via an inside access panel.
Current Volvos:
Kuhnboy
Post by Kuhnboy »
I could contact the shop that replaced it, as I said it was the PO that had it replaced.
