Drivers side low beam
DwightKshrute
Year and Model: 2004 Volvo XC70
Post by DwightKshrute »
Hello, any help would be amazing. So my drivers side low beam is out, replaced bulb, still out, fuses are okay. The igniter is bad but switched it with a working one but still no light. pretty confused. \any help is great, thanks.
Has thanked: 1610 times
Been thanked: 4071 times
Bears, bulbs, battlestarGalactica
Swap with the passenger one, known to be good,
If that fails, work backwards up the wiring harness with a voltmeter to find the fault
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
Not sure if this is your problem, but I was having problems with intermittent low beam. I could wiggle the socket and the low beam would come on, but it would eventually go out again. So I replaced the socket with a ceramic version about a month ago. No problems so far.
