New member. Just bought a v70r
HankScorpio
Year and Model: 2006 V70R
Post by HankScorpio »
Hi all.
Just joined the forum after buying my first volvo. I have a 2006 v70r (jap import). 55k miles. It comes with the 6 speed auto box, so presume this is one of the later boxes which (I hope has the newer Haldex). Has new suspension all round which wasn't installed correctly at the back, so got a fair few hundred quid knocked off for that one.
A few known issues:
Needs new disks and pads
Rear wiper doesn't work
Rear washer leaks into cabin (needs a new plastic connector)
Stereo doesn't work (could be din cable to amp, back in the multicoloured spaghetti tomorrow). Going to get it sorted and then replace with an android head unit.
Battery keeps going flat because I keep leaving the keys in it (was driving an A6 where I just jumped in a pressed a button to start and jumped out at the other end, it's taking a while to get used to a key again)
Strange Japanese sat nav needs removing. Pop up screen on dash has been replaced with something ugly. Sat nav will be on the new head unit, so probably just going to blank it off.
Got it booked in at the garage tomorrow so we can check underneath and all four corners. Probably start adding a bit to the list.
This place has been great help already.
Advice worth what you just paid for it
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Country of origin = Sweden.
Leaving the key in the ignition shouldn’t run the battery down. Leaving the key turned “ON” will run it dead.
HankScorpio
It needed a new battery anyway :D
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Welcome to MVS. 55k is low, low miles. Good job. She's a beauty.
R 90k service item checklist Various services I did to my 2004 V70 R auto
Volvo awd system guide Haldex info
Also -> Amazon link
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
She certainly looks nice and has low mileage!
If she sat for awhile then check for seal leaks.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Nice caR, welcome to the forum!
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
HankScorpio
Okey dokey - back from the garage where I've been under the car.
This car looks like it's never been driven in the wet. It is spotless underneath (and pretty much completely under sealed). Suspension all good baring a bit of dodgy clipping up of cable by the ten thumbed spanner monkey who changed the suspension. He also torqued the whells up to around 1 billion Nm.
Bad bits:
Anti rollbar bushings looking a bit perished. Still fine at the minute though.
Heat shield/outer layer on back box is rusting. Exhaust still fine.
Going to need to look at AWD. Front and back box is a bit oily (only bits that are)
Needs new rear pads
Good bits:
Nearly everyone in the garage loves it
Being asked if it used to be a showcar as it's so clean and straight underneath.
Watching the guy trying to undo wheel nuts :lol:
Brakes aren't as bad as I thought they'd be
Overall I'm really, really, happy with the car. For a 14 year old car, it's in top notch shape. Hasn't thrown up any fault codes and looks very straight and rust free.
Just need to sort the rainbow spaghetti for the stereo, treat the leather and fix rear wiper and we're good to go.
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
¡ ƃuıuunʇs
Manov
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
As far as the oil on the underside of the transfer case/bevel gear, look up above it, up to the turbo. Just about every turbo P2 I've looked at leaks at the turbo's oil return line. It's really nothing to freak out about if this is the case. All of our cars leak a little bit from that exact spot.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
HankScorpio
Thanks very much. Back in the garage tomorrow (rear pads, handbrake cable, aircon recharge and wheel alignment) so I'll have a look.
Underside of the car doesn't look like that now. The wife drove off in it the other day and I could see mud and grass hanging off it :roll:
