Are master window switches supposed to be plug n play? The DS window does not work on my partner's "project" '01 V70 X/C. I put a new working motor and window rail in from the local pick n pull, old window had come off the rail and bent the rail/transmission assembly. Dealership was working on some other stuff on the car, and they said the window switch is plug and play, but I got a used one from eBay which was listed as tested/in working order; I plugged the new switch in and none of the buttons worked.
Are window switches plug and play, or do they need to be programmed? PNs on existing and the "new" switch are identical.
Master Window Switch Question
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
They are not necessarily plug and play even though the P/N may be identical. The little white label(s) indicate how they’re programmed and that has to be a match between the old and new switches.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I’ve always used a official Volvo parts lookup and when using chassis # I’ve never had an issue with used switches from scrapyard/ebay. Is it the identical PN?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
i swapped mine, part numbers matched and it works..
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Jonboy74
- Year and Model: V70 2.4T, 2002
- Has thanked: 119 times
- Been thanked: 15 times
Yes, they are programmable. However, as others mentioned, if you get a junkyard pull with the exact same numbers on it, it should work without programming.
I ended up finding one on eBay for relatively cheap and it worked like a champ, no programming needed, but I made absolutely sure that the numbers all matched.
Goodnight Elizabeth,
Jonboy
Jonboy
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
With the same PN, it should be plug n play. I've personally had success.
I'm not sure if you also need to shut the driver door, and lock/unlock three times with the key fob. I seem to remember doing that but that may have only been to program the locks.
If no buttons work, double check fuses, relays and that your new master switch is getting power. Do your rear window switches work?
chrism
It seems I recall someone in a prior discussion saying that the switches were plug-n-play up to a certain model year, like around 2000, and then for anything newer you had to consider the programming. Maybe it was at the P80/P2 break???
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
Ive had all the same issues with two 02' xc70s. I took apart the switch box finally and cleaned all the metal contacts for each window button. Put back together and they all worked. Sometimes those connections just get filthy. I've also done the same thing with an old Saturn and an old Chevy Blazer.
- 1458 Views
Last post by beigg
- 1709 Views
- 18 Replies
- 3751 Views
Last post by FLXC90
- 2447 Views
Last post by halseyfolk
- 1019 Views
Last post by wizechatmgr
