Hy Folks,
I hope you're all fine by these days. I've driven my car this morning out of town. I've respected the time to let the car get on temperature, driven cool 'ill the motorway, respected the speed limits. Everything is fine, and the clutch does its job. A hour outside with my dog to have a walk.
When I came back, the engine idle started to be a little bit unstable. I get to the parking, I waited a couple of minutes and the issu seemed to have disappeared. As I don't like surprises, I would replace parts on a preventive way and need your help to choose the rights ones :
- The IDLE Control valve Ref. 9454745
- Air mass sensor Ref. 1366220(Bosch)
- Camshaft pulse Ref.9146108 (Bosch)
Spark plugs, ignition cable kit rotor and distribution cap are brand new (either OEM or well known brand).
Do you recommend me some specials brands that are as good as OEM, or do I have to stay on these references ?
edit : a little question :
To what does this part serve ? Does it "break" often, and what is the sign this part is out of work, does it have an influence on the way the engine works ?
Manov
850 Need advice for new parts Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
That in the picture are knock sensors.
They never fail but their wiring could make problems.
They are under intake manifold,just by pcv box.
Iac valve could be cleaned with a brake cleaner and it is
99.9% success.
Maf sensor do fail,but more common is that it's connector that fails.
Iac valve is Bosch,
Maf MUST be Bosch
Knock sensors MUST be Bosch.
Generally....all sensors on these cars MUST be BOSCH(oem),nothing else will work or it will have wrong readings and wrong data(out of spec) sent to ecu.
99.9% success.
Iac valve is Bosch,
Maf MUST be Bosch
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 672 times
- Been thanked: 163 times
Salut misha,
Thanks much much for yourhelp.
I have my answer. I will clean my iac valve as you recommend it.
Manov
Manov
- Has thanked: 987 times
- Been thanked: 1075 times
Glad to hear that pesky clutch problem is over.
Roll on!
Roll on!
- 980 Views
Last post by polskamafia mjl
- 1265 Views
Last post by huzzsaba
- 2311 Views
Last post by rockfosgte
- 1674 Views
Last post by wes39153
- 1550 Views
Last post by tryingbe
