The 07 S60 2.5T fan will squeak when the car is moving forward from a stop or coming to a stop. Bearing is sloppy but hoping it's still be okay with some lube. Can't wait for warmer weather.
noisy blower fan
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Re: noisy blower fan
- MoVolvos
Cold if you lived most of your life in CA
- Has thanked: 1505 times
- Been thanked: 3818 times
That makes a SNR OF SQRT(1) = 1br0dy519 wrote: ↑06 Feb 2026, 10:57@abscate please note a sample size of n=1erikv11 wrote: ↑03 Feb 2026, 15:43On my S60, the blower motor started whistling in the winter of 2018. I still haven't replaced it (viewtopic.php?p=643927&hilit=garage#p643927). Sound never got much worse, and it makes no noise at all in warm months. Just one data point and YMMV, but FYI.
- Been thanked: 472 times
I have saved many electrical motors by lubricating the bushings. Very often, ppl call it "bearing", but it is essentially a "bushing", a cost-cutting measure in places with light load and simply spinning around. A bushing is cheaper than ball bearing:
- Portable electrical space heater...1 drop of oil every 5-7 years.
- Hair dryer motor...
- I have an old Bosch clothes dryer...same thing...1 drop of oil every 5-7 years.
- The only problem with Volvo (or any car) blower motor...
it is a contortionist position you assume to get it out of the car: it is not a pleasant job as you get older.
Once the blower motor is on a bench, it is VERY EASY to lubricate it. I showed the tricks in 2005 XC90 forum: I did it almost 10 yrs ago, so far so good.
Another benefit of lubricating the motor shaft...1 less item going to landfill site...
I managed to silicone spray lube my p2 blower which would chirp on deceleration only. Still good
- Has thanked: 292 times
- Been thanked: 765 times
This is a great idea, give it a quick spray in situ. I might actually try it! Maybe next cabin filter change.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
I searched and couldn’t find this job. Did I make this up in my head? My blower definitely was noisy and now it isn’t. Maybe I replaced it?
- 1037 Views
Last post by oragex
- 14 Replies
- 4657 Views
Last post by bichinavolvo
