850 N/A Throttleplate Modifications
This topic is in the MVS Volvo Repair Database » 850 N/A Throttleplate Modifications
sconeman
Year and Model: 98 V70R Manual
Post by sconeman »
make sure your throttle body is closing completely if it's even open a little the IAC has a hard time compensating for it. The linkage has to be altered or you can grab the linkage off the donor car to make sure the plate is closing fully.
BTW I sell a custom hose that easily allows you to connect the larger NA TB to the stock intercooler piping. I also have TB's, 960 plates and NA intake manifolds in stock although they're aren't listed yet. I'm planning to put together bolt on kits for 93-97 Turbos.
Kristian
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Just found this post. Is this a considerably noticeable change?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
YES.
'98 S70 T5
2016 Chevy Cruze Premier
Fish stick88
Awesome! *Now looking for a 960 throttle body + plate*
I assume you have one? If I just put on a new throttle body gasket 1 month ago, can I re-use the same one?
or, should I order (more what I'm thinking)
jblackburn
It does not apply to turbo models, but I helped someone do it to a NA and there was a noticeable improvement around town.
You'd need to get a new gasket. And the throttle plate itself will just swap out.
'98 S70 T5
Fish stick88
Plate, idle linkage, and sensor all will?
jblackburn
Not sure. I don't think so, as the RWD engine is mounted in the opposite direction - I would think the linkage is different.
Just the plate is all that you need to change.
'98 S70 T5
Fish stick88
Just out of curiosity. Why would Volvo have this "feature" if it limited the acceleration?
mtbmx
Year and Model: v70 1998
Post by mtbmx »
i found 960 plates online for under 4 bucks, but it says for 67mm housings. So does that make the plate 65mm?
whoa
Year and Model: 850 Turbo Wagon 1996
Post by whoa »
Just my guess/opinion here. You are not increasing performance in any way by doing this modification. All you are doing is changing how far you have to push down the pedal to open up the throttle a given amount. So after the mod, if you're accelerating more, it's exactly what you could have done by flooring it. You just feel like the engine is more responsive because you feel like you're not giving it much gas. But you are.
1996 850 Turbo Wagon
