Hi, I have a 1992 940GL and I'm having trouble installing the water pump correctly. There's a 5/8" metal line which attaches to the water pump that I can't get to seal correctly. I don't know what this line is for, maybe the air conditioner? There isn't a typical male/female type fitting so I'm not sure how attach it.
Thanks in advance for any help!
Jim
Trouble Installing Water Pump - 5/8" metal line won't seal
takeiteezeee
- Year and Model: 940GL 1992
jimmy57
- Been thanked: 320 times
the pipe should have a rubber seal on it and a bolt holds into pump.
Put the seal on the pipe against the ridge, Lube the seal with pure antifreeze so it will slip into hole in back of pump.
