How often do you guys flush your ATF?
How Often Should You Flush Your Transmission Fluid?
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
A 15/16" works as well (almost same size as 24mm). I also used a socket and short extension, which is nice because you can use a 6 point socket with less chance for rounding out the large bolt.
1995 850 GLT Wagon w/ 200,000 miles
SimLyons
- Year and Model: 2001 V70 T5
Home Depot has it. I forget the size. I have 2 sizes, one for the 850 and one for the S80T6. Just pull the top hose and measure the diameter of the inlet or outlet. Mine fits a little tight which is good. Only leaks a few drops when I pull it off.
Sim
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I do mine every 25,000 miles. The drain and fill x3 every 50 - 100 miles.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Once a year no more than two depending on color or slight change in driveabily. On my other cars drain and fill if lazy or else flush especially on the Volvo.
I have a 850 Turbo, I wanted to have a drain and fill done on it by a shop and not mess with it.
They told me that they will not do one on a car with more than 100k, well, I am well past that at 201K.
So should I do the partial drain and fill slowly myself?
Brad
850T
850
244
244T
850T
850
244
244T
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I did the drain and fill 4 times over a period of about 2~3000 miles. Now I drain and fill once every other oil change, about 10K miles. Shifts fine and still looks pretty clean. Brad850, do the drain and fill yourself, about 3.5 qts per drain. Do one, drive for a couple/few 100 miles, do another two/three more times and you're golden. Don't try to do say 2 or 3 drains back-to-back, don't shock your tranny. Use off the shelf DEXIII fluid, nothing special, I used PEAK ATF DEXIII and it works fine.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
SpeedyPete
- Year and Model: S70-T5, 1998
HI all I just do 1 drain and fill when I change my oil which is every 5K using synthetics. Regards, SpeedyPete
- dosbricks
- Been thanked: 4 times
1/2" id. It comes in thick and thin wall at the hardware store. Get the thin because it's easier to squish on and still grips tight. About $3 for 5' length which is just right, and at that price it is easier to toss it than clean it up. If you think about it, probably no worse for the environment. I flush every 30k or 2yrs so it's not a big deal--cost or otherwise.Reys wrote:Anyone know the size of clear tubing I need to drain the atf from the hose going to the radiator? I don't think it'll cost me much as ipd has it
8 year update on this thread.
I’m now running three slush boxes, all on Valvoline maxlife synthetic ATF
All cars got three drain and fills over a month when they joined the fleet, then get the 3-4 liter “ update” each summer in the nice weather during the nice weather
- 11 Replies
- 2741 Views
Last post by oragex
- 11 Replies
- 1215 Views
Last post by MoVolvos
- 1582 Views
Last post by Turbo_Boss
- 24 Replies
- 4186 Views
Last post by bigbrain
- 31 Replies
- 5648 Views
Last post by VolvoOwl98
