Do it yourself ABS module repair. Topic is solved
This topic is in the MVS Volvo Repair Database » Do It Yourself ABS Module Repair
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Make double sure the large, hinged, hooded connector is well seated. The hood needs catch the pins on the connector portion on the module itself to draw the connector down in place securely.
Been thanked: 4065 times
I think I would give Matty Moo a call, especially if you are in Ontario and can cross the border into MI easily!
tzanis
Year and Model: 1997 850 GLT
Post by tzanis »
Ozark Lee wrote:Make double sure the large, hinged, hooded connector is well seated. The hood needs catch the pins on the connector portion on the module itself to draw the connector down in place securely.
thanks. I will go check it right now. :D
abscate wrote:I think I would give Matty Moo a call, especially if you are in Ontario and can cross the border into MI easily!
who is matty moo? yes, i am in hamilton ontario.
Midwest ABS sell replacement ABS modules tested and guaranteed.
I'm a happy customer myself
tzanis
Post by tzanis »
Thanks but I would like to repair it myself since I am in a really low budget.
anyway. I checked the plug again, and went for a drive, but the same thing happens.
btw this is how it looks.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
Large harness looks fine, just make sure it's seated down all the way.
Something to remember, your car is now 18 years old so you may have another issue outside of the module.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
tzanis
Post by tzanis »
thanks for your answer.
this is true. It is confusing though. Is there any possibility that it could be one or more of the sensors?
heyarnold
Year and Model: V70 1998
Post by heyarnold »
Thanks for this tut. I did this today on my dads 1998 v70, as the light had been on since the previous owner had it. I just reflowed and added some solder to the two power supply joints, fitted it back in and after driving about 50m, the light vanished. It took me about 3 hours to crack open the box though, I did it as neat as possible.
bappat
Year and Model: 850 1997
Post by bappat »
I used a 4mm socket instead of an E-5 torn socket and it fits perfectly for me. My socket wrench has a swivel head so the "tricky" bolt was not too difficult to remove.
bappat
Post by bappat »
Nevermind.
At least the car didn't skid.
