Stripped tension pulley torx - Bay Area
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Spray the nut with brake clean to clean out any gunk and avoid cheap Chinese torx bits which aren't hardened properly and loose their edge
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Samport
Year and Model: v70 1998
Post by Samport »
Dos,
sorry about the delayed response. It is a double wall construction so the magnet trick might not work. I thinks I leveled a a piece of wood across top of fender and measured down. Then drilled a small pilot hole. Don't really remember unfortunately. Used a 1.5 inch hole saw. Could've been smaller but 1.5" gave me some room if hole wasn't perfectly aligned. I found this method pretty much assured that I could get the stripped torx out.
dosbricks
Been thanked: 4 times
Post by dosbricks »
I like it. You came up with a good fallback position if things go wrong. Thanks for the reply!
dos
tersfilozof
Year and Model: 1998 s70 2.3
Post by tersfilozof »
Hello from 2024, I stripped in my s70. Car is sitting for 10 days because of this crap. How can i achieve this with a dremel? Any recommendation?
Been thanked: 4069 times
You probably have to put a hole in the wheel liner so you can get a tool straight into the stripped fastener like the photos above.
Na Zdrowie!
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I like the idea of laying a 2x4 or a bar across the fenders and measuring the distance. Then drill a very small hole where you think it should be and adjust accordingly. Could shine a flashlight through the pilot hole and see if the light lands where you need.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Is it still possible to wedge a piece of wood against the wrench and chassis to keep it from slipping and remove?
tersfilozof
it's already slipped. i'll. try to use torx extractor with 90 degree adapter. What do you think about this solution?
https://allegro.pl/oferta/milwaukee-uda ... 4018431054
MoVolvos
Post by MoVolvos »
tersfilozof wrote: 15 Mar 2024, 13:59 it's already slipped. i'll. try to use torx extractor with 90 degree adapter. What do you think about this solution?
Don't think there is enough room? Perhaps the next size up Torx in standard. Pound in using a wedged piece of wood sandwich between the frame and pulley.
