Stripped tension pulley torx - Bay Area
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Spray the nut with brake clean to clean out any gunk and avoid cheap Chinese torx bits which aren't hardened properly and loose their edge
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Dos,
sorry about the delayed response. It is a double wall construction so the magnet trick might not work. I thinks I leveled a a piece of wood across top of fender and measured down. Then drilled a small pilot hole. Don't really remember unfortunately. Used a 1.5 inch hole saw. Could've been smaller but 1.5" gave me some room if hole wasn't perfectly aligned. I found this method pretty much assured that I could get the stripped torx out.
- dosbricks
- Been thanked: 4 times
I like it. You came up with a good fallback position if things go wrong. Thanks for the reply!
dos
dos
tersfilozof
- Year and Model: 1998 s70 2.3
Hello from 2024, I stripped in my s70. Car is sitting for 10 days because of this crap. How can i achieve this with a dremel? Any recommendation?
- Has thanked: 1613 times
- Been thanked: 4075 times
You probably have to put a hole in the wheel liner so you can get a tool straight into the stripped fastener like the photos above.
Na Zdrowie!
Na Zdrowie!
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I like the idea of laying a 2x4 or a bar across the fenders and measuring the distance. Then drill a very small hole where you think it should be and adjust accordingly. Could shine a flashlight through the pilot hole and see if the light lands where you need.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Is it still possible to wedge a piece of wood against the wrench and chassis to keep it from slipping and remove?
tersfilozof
it's already slipped. i'll. try to use torx extractor with 90 degree adapter. What do you think about this solution?
https://allegro.pl/oferta/milwaukee-uda ... 4018431054
- MoVolvos
.tersfilozof wrote: 15 Mar 2024, 13:59 it's already slipped. i'll. try to use torx extractor with 90 degree adapter. What do you think about this solution?
Don't think there is enough room? Perhaps the next size up Torx in standard. Pound in using a wedged piece of wood sandwich between the frame and pulley.
