1998 V70xc Bluish white smoke when I open up throttle
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I recently purchased another Volvo, a 1998V70xc to add to our small collection('04 XC70/'96 850). I got a sweet deal on her cause of a few minor issues(key was stuck in ignition/needed battery/bald front tires/oil filler cap needed new gasket). Anyway some lines/hoses near rad have oil seeping from them, they look like oil cooler lines and the turbo air intake tubing. The PCV system definitely need to be serviced. I put new double platinum spark plugs, Mobil1 5w30/Mobil 1 oil filter, new battery, front tires and I put some seafoam into the gas tank. It will blow smoke when I get on the throttle.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Year and Model: Many Volvos
- Been thanked: 76 times
Deal with the PCV and it will likely clear up the smoking problem. If that doesn't clear things up then do a compression test. If you have low compression and smoking then it may be the piston rings.
Ben850
- Been thanked: 7 times
That will make smoke until the Seafoam is run through.
I enjoy the smoke while knowing it is harmless.
93 octane in the tank next fill.
It has an interesting smell as well. Somewhat sweet, with a texture of elderberry?
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
What brand spark plugs are those? In any case, these cars run best with OEM Volvo plugs.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- shiloh51933
Volvo plugs850 LPT wrote:What brand spark plugs are those? In any case, these cars run best with OEM Volvo plugs.
- Has thanked: 311 times
- Been thanked: 817 times
The Volvo plugs for a turbo are single electrode, not double.shiloh51933 wrote:... I put new double platinum spark plugs...
Ben850
Collection is a nice way to explain it.
What color is yours, by the way?
I had added the same to my collection, hoarding? I don't know. I did not need another, but there seems to be an abundance of the '98 XC lately.
I believe this must be their time for passing from the pragmatic existence.
I am having fun with these cars at the moment.
They have inspired an old hobby, as well as a couple nice vehicles I am keeping all to myself.
Ben850
Simply Bosch Super Copper for each. Gapped @ .026. Let them burn and replace.
When I say "replace", I have not had to even do that in the last four years. Re-gap may be a useful term.
The cars seem to love them.
In my experience so far.
Not expensive either, at around $2 EA.
To address the condition this thread calls for, bluish white may be a puff of oil coming from either the turbo, valve seals, other possibilities.
Was the engine idling for long, fully warmed to running temperature? these are considerations as well.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If you ask me 5w-30 is pretty thin oil for these cars and for climate you are in.
5 or 10w-40 should be used in these cars with a lot of mileage on the clock.In the other words...Synthetic 5w-40 for turbo and semi-synth 10w-40 for non turbo for moderate climate all year round.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- shiloh51933
That's what the factory specs call for, my understanding is double platinum means there's platinum on center and ground electrode. My factory Volvo plugs for my n/a 850GLT have 3 side electrodes and all spark plugs have a center electrode/side electrode...so I'm confused about your statement that turbo Volvo plugs have single electrode.erikv11 wrote:The Volvo plugs for a turbo are single electrode, not double.shiloh51933 wrote:... I put new double platinum spark plugs...
- 2266 Views
Last post by Sommerfeldt
- 2025 Views
Last post by Ben850
- 1594 Views
Last post by precopster
- 385 Views
Last post by martinbarn
- 1498 Views
Last post by red0161
