Had a no start on the 850 and it was the Cam Position Sensor. Replaced it and was good for a few months.
No start is back again and seems like it is very likely the CPS again. Tested the fuel relays and swapped some wires etc... seems like CPS is the suspect. Any idea what would cause a CPS to fail so soon again. Used Bosch Brand last time? also no codes. In fact A-6 does not light which seems odd too. Any CPS advice would be great. Thanks
95 850 No Start - 2nd CPS
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
If you route the CPS wires too close to spark plug wires the car won't run. Check for threads on correct routing.
cuhfs
Moved them away the mount to the engine had broke last repair so it flopped more than usual. Moved wire away from all and still no start. Could that have killed the part?
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 1618 Views
Last post by RickHaleParker
- 9 Replies
- 1786 Views
Last post by erikv11
- 860 Views
Last post by kahl
- 3044 Views
- 811 Views
Last post by MadeInJapan
