95 850 No Start - 2nd CPS
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Had a no start on the 850 and it was the Cam Position Sensor. Replaced it and was good for a few months.
No start is back again and seems like it is very likely the CPS again. Tested the fuel relays and swapped some wires etc... seems like CPS is the suspect. Any idea what would cause a CPS to fail so soon again. Used Bosch Brand last time? also no codes. In fact A-6 does not light which seems odd too. Any CPS advice would be great. Thanks
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
Has thanked: 1609 times
Been thanked: 4065 times
If you route the CPS wires too close to spark plug wires the car won't run. Check for threads on correct routing.
cuhfs
Post by cuhfs »
Moved them away the mount to the engine had broke last repair so it flopped more than usual. Moved wire away from all and still no start. Could that have killed the part?
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Was the Bosch CPS new or used?
Get some used CPS from junkyard and try again.
