1999 s70 non-turbo.
Just put a new dash in. Finished everything, connected the battery, went to turn the key to start-
and no start. No cranking either. Just the sound of the starter.
During my dash swap, I did put in a used clockspring. I connected everything up to it but I don't think I was careful enough with it.
I found this thread: https://www.matthewsvolvosite.com/forums ... hp?t=34639
#11 is what I did not do...
Could this affect my no start?
99 S70 Base. No crank, No turnover after Dash swap
- ashlee2319
- Year and Model: 2000 V70 NA
- Has thanked: 3 times
- Been thanked: 2 times
2000 V70 N/A
1999 V70 GLT - Current project car
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You forgot to connect something.Check ignition lock connections.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- ashlee2319
There is a long wire hanging down near the alarm module ( behind steering wheel), with spring like end to it. It has a flat end I can push down on and has a tiny spring back. I can't figure out where that goes...
This dash is from a c70 and the wiring wasn't 100% mirrored.
2000 V70 N/A
- ashlee2319
- misha
This looks like some kind of switch,not just a wire.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
That's a switch belonging to an alarm system, if I'm not way off the mark. Not a stock one either, so there may have been modifications made to the wiring. Could be a major PITA to track down.
Also, remember that there are certainly unused connectors and stuff back there, so you shouldn't assume that everything goes somewhere. A quick glance at the accessories catalogue for these cars show a myriad of stuff, and I myself struggled like a madman with some wires and a connector in my old T5-R, only to find that it was the wiring for the optional trunk area ventilator fans and switch.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- ashlee2319
Could the alarm system preventing it from not starting? And how about the clockspring piece?
This dash allowed me to connect that small alarm piece located on the outside top of the dash, closest to the windshield.
As I repeatedly tried to start it, I heard erratic clicking and then my interior lights would flicker. I always feel like I am thorough with matching up wires, but I will remove the steering wheel and check again.
Otherwise, my last resort is switching out the wiring harness from my old one.
2000 V70 N/A
Sommerfeldt
Erratic clicking and flickering is probably the key. Something's hooked up wrong, or not at all.
The alarm system could absolutely prevent starting - and a jerry rigged aftermarket one could be an absolute pain to untangle.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
obayha
- Year and Model: V70 1999 Base
If all else fails. This may be the best option.ashlee2319 wrote:Otherwise, my last resort is switching out the wiring harness from my old one.
Second time removing a dash should be faster, I hope.
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- ashlee2319
OK, I switched out the wire harnesses, back to my old one.
Battery is dead. Went to jump it- NO start. All of my interior lights come in as well as the radio. No more erratic clicking.
Turns out the connection from the new harness included a key ring connection- no match for my car.
Could it be the starter? I don't see how a simple wrong connection could have caused this much trouble...
2000 V70 N/A
- 799 Views
Last post by shevolvo45
- 995 Views
Last post by brent72
- 1334 Views
Last post by Ethan Rode
- 15 Replies
- 602 Views
Last post by jonesg
- 3629 Views
Last post by Empathron
