Air cleaner
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Yep.
One is going to the lower half of the housing in the lower left corner.The other one should go to a vacuum tree.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
Yes.
Turbo car look here https://www.matthewsvolvosite.com/forums ... hp?t=63615
Non-turbo car look here https://www.matthewsvolvosite.com/forums ... =1&t=65002
- misha
Remove negative battery cable for 10-15 min to reset ecu.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
1200 rpm isn't right. While idling idling, Pull each one off and plug both resulting holes to see which one is putting in air. Then go backwards on that hose to fault trace to find the vacuum leak. It might be the solenoid or temperature valve for the hot air system too, or just a hose or connector leak- more likely.
- misha
Before you connected those vacuum hoses...idle was ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- dosbricks
- Been thanked: 4 times
There is no stupid on this forum. These cars are like a good wife--you are always learning something new about her.
- 10 Replies
- 2232 Views
Last post by volvolugnut
- 1102 Views
Last post by crisnumbertwo
- 1615 Views
Last post by oragex
- 26 Replies
- 4017 Views
Last post by DARK_BLU
- 15 Replies
- 8416 Views
Last post by Jewl1215
