I need to replace the inner and outer tie rods on my 98 V70 and could use some advice about what parts I need to buy. I understand that it depends on what steering rack you have but I don't know how to tell the difference.
Also, my car has about 150K miles and I may do the ball joints at the same time...any thoughts? I've already done the struts (every part) from top to bottom.
98 V70 Tie Rods - Replacement
Identify Steering Rack Type from Data Plate
- Year and Model: Lots
- Been thanked: 128 times
Something about one of the digits in VIN being a 5 for SMI rack and 4 for TRW rack.
FCP Euro have listings for both SMI & TRW racks.
Matty Moo seems to clear up which one the guy has in this thread: http://volvospeed.com/vs_forum/topic/13 ... 8-s70-t5m/
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Hope this helps. Data plate right side in engine bay inner fender. My poor notes show the left side of the plate.
- image.jpg (142.38 KiB) Viewed 4202 times
- image.jpg (150.25 KiB) Viewed 4202 times
- image.jpeg (213.92 KiB) Viewed 4202 times
98v70dad
- Year and Model: 98 V70
Thanks KAHL. Its probably helpful to me but I don't understand how that deciphers anything. Maybe it will be obvious when I look at the data plate.kahl wrote:Sorry, notes show right side of data plate.duh
- Has thanked: 311 times
- Been thanked: 817 times
Totally worth it to just take a look at the boots, the TRW racks say "TRW" on the rubber boot, if you see that then you have solved it for your car. The TRW racks are much more common, too.
The TRW inner and outer tie rods have been foolproof for me as replacements (have only had TRW racks so far).
98v70dad
I'm still a little confused. The plate in the photo you posted shows the letter "A" in the position you say should show a 4 or 5 (bottom entry, right side of plate, rightmost digit). My car has a 5 in that position (I think ... hard to read) which is SMI according to the info you've posted. The dealer told me SMI also, but he didn't check the plate or the VIN.kahl wrote:SMI Is 5 and TRW is 4.
I'm stopping by the worldpac place on my ride home to see what they stock. I want lemforder inner and outer tie rods and lemforder boot kits, but I'll see what they have.
