1998 s70 here quit blowing ac. Found 10 amp fuse blown and replaced, AND also the icecube (relay/fuse) -- black one
still nothing.
Bypassed the pressostat plugin (or low pressure) still nothing. have 12v going to plugin..
replaced the pressure switch down there by the light
still nothing
bypass the icecube relay in the fuse box and voila! I check pressure at about 45.psi
any ideas? ---maybe the pressostat? ecm?
thanks
A/c compressor only kicks on with bypassing main fuse in fuse box..
It sounds like the AC clutch is pulling too much current. That probably means its at end of life. You can replace the clutch without replacing the AC compressor or breaking lines.
AC pressure measurements don't mean too much in diagnose unless you carefully control the conditions - If your AC was working well before, go for the clutch replacement - used is fine.
Set the gap first!!
Set the gap first!!
Probably not. If its pulling too much current, there is an electrical fault. You could try measuring it by going to a 15 amp fuse as a temporary measure, or if you have a good ammeter, measuring the resistance of the clutch connections while they are disconnected from the car. The need to be greater than 2 Ohms or so to stop that fuse from blowing.
You are risking burning up your car bypassing the fuse or using the oversize one - Legal Department.
- Has thanked: 2200 times
The former!
That means a wiring fault between the clutch and AC relay is pulling the current.
Download the wiring disgram from the inter webs and use that as a guide for finding the fault.
Double check the resistance on the new clutch to confirm its a good part
cichy1012
- Year and Model: 1999
one more questions. as far as fuses and relays that pertain to this.-- the only fuses and relays for this are in the hood correct by the fire wall? nothing in the glove box or on the side? I know im 1994 940 a solder spot broke off in the panel on the board where the knobs were that needed to be fixed and that got my 94 up but i assuming this is different in the 98's
- 18 Replies
- 5422 Views
Last post by wizechatmgr
- 1152 Views
Last post by Cookeh
- 12 Replies
- 2118 Views
Last post by humbertoflores63
- 11 Replies
- 1074 Views
Last post by volvothaifactory
- 1047 Views
Last post by Volvo S80
