HI, I'm planning to use this on my cam cover. What is the preferred method for applying - use a small foam roller or just squeeze out a bead line from the tube?
Is there any curing time?
Would appreciate any tips from those who have used this. Thanks!
Permatex Anaerobic sealant
The foam roller method gives you nice even coverage on the sealing surface. I wouldn't try this job any other way. Make sure you cover every little portion of the sealing surface.
There's no curing time with an anaerobic sealant ... it stays wet until the surfaces are joined together and it drys in the absence of air.
I used the Elring brand sealant from RM European and a small foam roller from Michael's craft store with excellent results. I suspect the Permatex brand sealant will be fine as well.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Rubber roller and Permatex every time.
- Has thanked: 311 times
- Been thanked: 817 times
Yes - applying a bead would be a getting it all wrong. Many people overdo it with the roller too: you just want a very thin layer, for example enough to make it light pink when you are using the Volvo brand (I don't know what color the Permatex is).
Nicely done:
vs. too much:
Nicely done:
vs. too much:
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I used the Permatex too...it is pink like the pictures when applied correctly with a foam roller.
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
I squeezed out a bead (no roller) and have not found any ill effects. I did not GLOP it on and used a very small diameter bead.
It's been over a year and all seems well.
I used the Permatex Anerobic.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
