Need help with error codes Topic is solved
To bad you live to far away otherwise I would have let you do it aswelldoublebug wrote:tomorrow I will do the same repair but will change the left relay.
Perhaps I should replace em both in precuation. But I read some where about the OHm's and things... I'm not so good at this, I have found a standard relay at 30 amps 12 volts. But are all relays configured same way over the pins so nothin bad happens also does the apms, ogms in coil etc make any difference?
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
no need of reconfiguration just replace relays and that all.
BTW
Recently I've been in Sweden. Visited Volvo factory. But at that time you had 2002 MY
BTW
If you have questions about Volvo firmware ask me. I may know an answer
doublebug wrote:no need of reconfiguration just replace relays and that all.
BTW
Ah cool, so that means you might be the brain behind the brilliant idea of soldering the relays to the CEM.. mohaha "joke". SO you work for volvo or?
- 3185 Views
Last post by 2001downunderxc70
- 800 Views
Last post by Ozark Lee
- 10 Replies
- 2761 Views
Last post by alemao4100
- 2839 Views
Last post by aswresm
- 2165 Views
Last post by wizechatmgr
