Thank you all for your contributions. I really appreciate.
My next project is How to properly route a Cold Air Intake as I earlier just remove the old air filter box and replaced with the cold air intake beside the battery resulted in P0172. I read that " not enough oxygen was entering the engine. MAF sensor is brand new Bosch.
Anyone with ideas probably with pictures how to properly do this to avoid any error codes ?
What is this hose connected to ?
- Been thanked: 4068 times
That isnt a lack of air intake. You probably knocked off a small vacuum hose(s) on the back of the air filter box, and the resulting vacuum leak is triggering the short term trim fuel code.
- Has thanked: 311 times
- Been thanked: 817 times
Agreed, vacuum line(s) probably off. Be sure to check the nipple on the end of the intake manifold too. Replete with pictures viewtopic.php?t=65002
While you are in there, I'd replace any vacuum lines that appear suspect.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
S/V 40 have 4 bolts instead of 5 and bolt pattern is wrong on 1996-2004 models.
Newer s/v40 2004-2012 have 5 bolts but offset and center bore are wrong.
So...they are not interchangeable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Hi guys,
I'm trying to change All Valves and Hoses one step at a time and now I got stuck with these two strange Vales.( see attached photo).
Do anyone know where to buy those two Valves and roughly how much do they cost ?
- Capture+_2018-09-05-14-22-06.png (658.63 KiB) Viewed 744 times
Check valves, and I believe they are no longer available new. Junkyard is probably best bet.
- misha
Those are just one way valves....any brand or car manufacturer will do...just need to match the hose diameter.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 539 Views
Last post by erikv11
- 595 Views
- 10 Replies
- 3534 Views
Last post by Gnarledbark
- 2349 Views
Last post by Orchid70
- 4577 Views
