I have a 1980 262 Bertone Coupe
The car will not re-start if the engine is warm. Cold starts are fine and car will run and drive after the cold start. However, if you turn the car off once and then try and re-start, it will not start. The motor turns over but there is no fuel pumping. IF you remove the fuel lines there is no fuel present.
Already Changed:
Fuel Filter in tank and outside tank
Fuel Pump
Fuel Relay
Something is not talking to the pump after car is shut off until car cools off.
Won't Re-Start Once Engine Is Warm..Any Help?
frumharlem
- Year and Model: 1980 262 Bertone
- RickHaleParker
- Been thanked: 980 times
Did you try pushing the accelerator to the floor?
Fuel pump regulator?
Any exhaust leaks, between the fuel pump and the fuel tank?
Active
Past
Past
frumharlem
I think it is the main computer, that needs to be replaced.
I can’t find the one part anywhere.
Hello I am new here today u have a 1985 Volvo turbio wagon just bought three weeks ago great car really clean .But although it run great it only gets about 15 mpg I know its a tank not a Honda but I most people I talk to say 18-23 any idfeas
- 10 Replies
- 2358 Views
Last post by erikv11
- 478 Views
Last post by Dieudonne
- 3556 Views
Last post by 93ForMe
- 4292 Views
Last post by chittychittybangbang
- 1789 Views
Last post by ejbj
