Won't Re-Start Once Engine Is Warm..Any Help?
frumharlem
Year and Model: 1980 262 Bertone
Post by frumharlem »
I have a 1980 262 Bertone Coupe
The car will not re-start if the engine is warm. Cold starts are fine and car will run and drive after the cold start. However, if you turn the car off once and then try and re-start, it will not start. The motor turns over but there is no fuel pumping. IF you remove the fuel lines there is no fuel present.
Already Changed:
Fuel Filter in tank and outside tank
Fuel Pump
Fuel Relay
Something is not talking to the pump after car is shut off until car cools off.
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Did you try pushing the accelerator to the floor?
Fuel pump regulator?
Any exhaust leaks, between the fuel pump and the fuel tank?
Active
Past
frumharlem
I think it is the main computer, that needs to be replaced.
I can’t find the one part anywhere.
SSTurbo
Year and Model: 1985 Turbo wagon
Post by SSTurbo »
Makes sense considering what you have done already and it is the computer that tells the pump when to operate I believe
SSTurbo
Post by SSTurbo »
Hello I am new here today u have a 1985 Volvo turbio wagon just bought three weeks ago great car really clean .But although it run great it only gets about 15 mpg I know its a tank not a Honda but I most people I talk to say 18-23 any idfeas
