New Axle Stuck in Transmission Topic is solved
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Re: New Axle Stuck in Transmission
Post by bmdubya1198 »
xHeart wrote: 25 Oct 2018, 08:32 After a struggle with stuck drive axle:
Ouch! There’s a good example of a snapped P80 axle. Hopefully that doesn’t happen to mine.
Has thanked: 1504 times
Been thanked: 3817 times
There is no way a 5 cm steel axle snapped off without a defect..
bmdubya1198
Probably aftermarket. These things are JUNK!
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
It was 2001 V70XC original - viewtopic.php?f=9&t=62641
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Doesn't look that bad, time to bring the welding machine. But a above, hopefully the carrier bearing & other staff inside didn't take a hit
I've heard it may work rotating a bit then trying to pull, rotate again and so on. Just hope it's not because of a too large size circlip
bmdubya1198
Being an aftermarket axle, it just might be. We had the same problem with an Autozone axle on my cousin’s S70, but fortunately we got it out.
I didn’t get a chance to work on it today, but I should be able to take care of it tomorrow. I’ll update everyone with what happens!
xHeart
Post by xHeart »
There were many comments against the aftermarket drive axle. CN90 wrote a comprehensive procedure which helped me rebuild too. More here viewtopic.php?f=9&t=62033
bmdubya1198
This is where I am now... got it out MAYBE another 1/2 mm. I can’t figure out how to get it out without damaging it, as I’d like to try to return it.
Has thanked: 292 times
Been thanked: 765 times
##!!#$@@%^@*@&*!^!%$%!#% aftermarket axles.
Seems like an oversize circlip problem, not sure how to remedy that. Seeing the pic I definitely think "needs a huge pickle fork." And clearance.
Maybe a couple of wedges, one on either side, drive them up one by one. You can even try wooden wedges to minimize damage to the trans case but this may be too stuck for that.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
'06 S60 R, 197k
