Hesitation on WOT (V70 2.0 T5 AWD 1997) Topic is solved
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
Re: Hesitation on WOT (V70 2.0 T5 AWD 1997)
Okay, fuel filter replacement didn't change anything
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
- Fiodor
This car isn't made to run E85 but I've put on a piggyback device that raises the amount of fuel per injection cycle so that I could have the proper AFR.
And I don't know what ECU is in the car.
I've left it to my mechanic who'll tell me tomorrow if he finds the cause of my issues.
I'll keep you updated, thanks for your help !
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Maybe that device is the source of your problems.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Fiodor
Update!
If I run with the MAF unplugged my problems disappear + my fuel consumption drops drastically!
does this make the MAF the definitive culprit?
- misha
Usually...bad Maf have totally different symptoms.
Is Maf that is currently on the car Bosch or something aftermarket?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
If it is not Bosch...it can cause unusual behaviour....pretending that it's working...but not properly...since aftermarket Maf doesn't have the same values as Bosch(OE) one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1505 times
- Been thanked: 3818 times
It might be the MAF or it could be an induction leak after the MAF. When you unplug the MAF, the ECU guesses the air flow by rpm, and it gets pretty close. It will run a bit rich, but it will run well.
- Fiodor
It's a Bosch MAF, the ECU is a moronic 4.4
It feels as if unplugging the MAF causes a performance loss.
The car doesn't stutter but it also doesn't pull as hard...
- 336 Views
Last post by hausmeister
- 28 Replies
- 3154 Views
Last post by misha
