Replace crank seal and oil pump seal
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Hi guys, can you tell me what I need to move out of the way to replace oil pump seal, and crank seal on my 1994 Volvo 850 wagon I don't have to drop the engine do I? I've seen videos where you don't have to. I need some insight on this. Thanks guys ......
- Been thanked: 4068 times
Timing belt comes off and then the harmonic balancer , or crank pulley.
Engine stays in
Engine stays in
loveMy850
Thank you so much Abscate, Story to tell, I had the seal replaced once before, and I was told a BiG Whopper.. Oh well live and learn. Thank You...........................!
It’s a harsh world out there, but MVS has your back.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Was it possible the last time they did the rear crank seal? That's a real pain in the backside to get at typically.
Also called the crank seal, and that one does require at least a transmission pull, if not an engine pull.wizechatmgr wrote: 12 May 2019, 00:45 Was it possible the last time they did the rear crank seal? That's a real pain in the backside to get at typically.
loveMy850
No, Thank goodness, it's the front, I've watched a few videos and I think the oil pump seal is directly behind it, correct?, mys well do that to don't you agree? she's had this leak for a few yrs. yeah I know, but it's not a bad bad leak, I'm just ready to get her back up to par. Shes been a lovely car, and shes ready for some: Let's Do This TLC.
- 9720 Views
Last post by tyguyc
- 12 Replies
- 4962 Views
Last post by ashgoldS60
- 22 Replies
- 10475 Views
Last post by ggleavitt
- 27 Replies
- 4449 Views
Last post by precopster
- 36 Replies
- 21102 Views
Last post by Achilles
