One more TB tensioner question
anbran
Year and Model:
Post by anbran »
Is it normal for the tensioner (mechanical) indicator to move as the engine warms up? This is the thing that you set according to the ambient temp at time of instalation...
My guess is that it is normal.
I installed it when the outside temp was below freezing...as the engine warmed up a bit, I turned it off and had a peek at the tensioner...it had moved towards the right (warmer setting area.)
1998 V70
Near Guelph, Ontario, Canada
pfeener
Year and Model:
Post by pfeener »
Yes it will change as the temperature of the engine block changes. The aluminum engine block will "grow" or expand as it heats up.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Yes, it is suppose to move to the right with an increase in temperature. If it's off, in a garage that is above 60 degrees (at close to room temp. as possible) you can readjust the tensioner to right in the middle with a hex or allen key.
