P80 mistake 20-666
Has thanked: 1609 times
Been thanked: 4064 times
When you are doing struts and rotors and your caliper bracket bolts bottom out before the brackets are tight.....
It’s because you mixed up a strut bolt with a caliper bracket bolt
Crappy caliper slide pins too
Second broken Sachs quick strut spring
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
Mmm... fresh anti-seize!
Has thanked: 311 times
Been thanked: 817 times
good lookin' rotor!!
Zimmerman FCP
850oldschool
I’ve been a Meyle guy for about 15 years. Just installed my first pair of Zimmies.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Post by FLXC90 »
And this pairs well with P1 mistake 310H55A, forgetting that you didn't put thread locker on the caliper mount bolts of your XC90, then wondering what the noise and grab are in the front end at 70 on the freeway, when the caliper shifts on the rotor because a bolt backed completely out! Which leads to pulling a wheel in the middle of an off-ramp to swap the bolt location until you can limp it to Tractor supply in East Nowhere, but they had the right sized M10 bolt and blue Loctite. Won't forget that again!
Current Volvos:
850oldschool
On a P80 you don’t need no stinkin’ loctite. Rust is your threadlocker.
Has thanked: 2197 times
Been thanked: 1851 times
:lol: :lol: :lol:
Neil
callahanoffroad
Year and Model: 1995 850
Been thanked: 53 times
Post by callahanoffroad »
850oldschool wrote: 06 Sep 2020, 15:07 On a P80 you don’t need no stinkin’ loctite. Rust is your threadlocker.
I still think the best signature locking mechanism that Volvo designed was steel bolts in aluminum housings. Allow to age in the engine heat for 20 years. That's one fine threadlocker.
850oldschool
They had to choose the appropriate aluminum alloy to get the bolts to seize like that. Ironically the more expensive higher strength alloys also corrode more.
