When you are doing struts and rotors and your caliper bracket bolts bottom out before the brackets are tight.....
It’s because you mixed up a strut bolt with a caliper bracket bolt
Crappy caliper slide pins too
Second broken Sachs quick strut spring
P80 mistake 20-666
- Has thanked: 1500 times
- Been thanked: 3812 times
P80 mistake 20-666
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
Mmm... fresh anti-seize!
- Has thanked: 292 times
- Been thanked: 765 times
good lookin' rotor!!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Zimmerman FCP
850oldschool
I’ve been a Meyle guy for about 15 years. Just installed my first pair of Zimmies.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
And this pairs well with P1 mistake 310H55A, forgetting that you didn't put thread locker on the caliper mount bolts of your XC90, then wondering what the noise and grab are in the front end at 70 on the freeway, when the caliper shifts on the rotor because a bolt backed completely out! Which leads to pulling a wheel in the middle of an off-ramp to swap the bolt location until you can limp it to Tractor supply in East Nowhere, but they had the right sized M10 bolt and blue Loctite. Won't forget that again!
Current Volvos:
850oldschool
On a P80 you don’t need no stinkin’ loctite. Rust is your threadlocker.
- Has thanked: 1839 times
- Been thanked: 1709 times
Neil
- callahanoffroad
- Year and Model: 1995 850
- Been thanked: 52 times
I still think the best signature locking mechanism that Volvo designed was steel bolts in aluminum housings. Allow to age in the engine heat for 20 years. That's one fine threadlocker.850oldschool wrote: ↑06 Sep 2020, 15:07 On a P80 you don’t need no stinkin’ loctite. Rust is your threadlocker.
850oldschool
They had to choose the appropriate aluminum alloy to get the bolts to seize like that. Ironically the more expensive higher strength alloys also corrode more.
