850 OBD Codes read
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Buddies !
New episode in Blue's history. Here are the codes and issues I've read today after Blue's autopsy. I precise I've checked the kilometers, and the car OBD unit announces 107 016 miles (172 226 kms) and 93 053 miles (149 755 kms) on the combined instrument. I think the speedometer must have been repaired. I've found a process to test all slots before to read codes, but I didn't do it yet. I didn't control any fuses also which should have been the first thing to do. Could it explain mute codes ?
A2 1 - 1 - 1. FUEL SYSTEM ok
A6 3 - 1 - 4. IGNITION. camshaft positon sensor signal absent or faulty (solution : replace the camshaft sensor)
A3 3 - 1 - 2. ABS. RH front wheel sensor open circuit or short circuit
A7 1 - 2 - 2. COMBINED INSTRUMENT (Trip Computer) temperature signal interval too long
B1 nothing. ELECTRONIC CLIMATE CONTROL ?
B5 nothing. SRS ?
B2 1 - 2 - 2. CRUISE CONTROL no speed signal
B6 nothing. ELECTRIC FRONT SEAT ?
What worries me is the missing on certains codes.
For A3, I've replaced the ABS sensors by new ones less than 2 months. It could come from the sensor ring.
For B2, Cruise control don't work yet.
For B6, the motor of the back of the seat doesn't't work, a cable may be out or the wiring.
The car starts well, always. But I smell exhausts gases, like all the gasoline was not burnt. A question of lambda sensor may be ? I see lot of OEM parts on Blue which could explain the presence of an A6 code.
Here are the pics of my OBD unit.
Experts Ones, it's up to you !
Manov
manovlov
Post by manovlov »
Hy,
So, I progress in bring help to Blue. Here are 2 boards, extracted from my 850 book. The thing I don't understand is on the "b" board, why I only see the "A" unit and not the "B"one, If I didn't make a mistake.
On the 1rst board is written : 17/7 : diagnostic switch A only.
May someone explain how to proceed ? I would like to test the wiring from the OBD unit.
Manov
Been thanked: 4065 times
A and B are the two sides of the ECU electrical connector, one connector with two sides
ECU 4/41
manovlov
Post by manovlov »
Salut abscate,
Thanks for the light... It means that on the two sides of the connector, the power comes only when the pin is plugged so ? And if so, what could be the reason to have non power then ? A cable cut ? Where should I plug the multimeter then ?
I will have a look to this post :
viewtopic.php?f=1&t=89234
theobviousfaker
Year and Model: V70 P3, 2010
Has thanked: 5 times
Post by theobviousfaker »
Hey, I also have a DTC 3-1-2 on A3, meaning "right front wheel sensor circuit open or short". There is a separate DTC for defective sensor, while circuit is ok. So before I try to replace the sensor, I would like to check the cable but don't know how. Has anyone tried this before?
The most comprehensive documentation about the ABS that I found is this: http://www.volvotips.com/index.php/850- ... ce-manual/
But in order to check the cable resistance, it requires the use of a special diagnostics box. It is to be connected to the ABS-controller. And it says "Do not directly probe control module connector." Any insight into why not?
I would like to directly probe the connector, but theres is no diagram which pins correspond to the front right wheel cable :( Maybe it is in the wiring diagram, but its unreadable. Does anyone have the original?
