(I actually meant a pressure tester for the intake, 2 plugs, one with a manometer where you can connect a compressor and test it for leaks)
For fuel pressure I'd check idle and blip throttle. I would not want a fuel hose in the cabin, maybe tape the gauge to the windscreen securely if you want to test it during a drive? Not sure if you really need to do that test, I would be very careful either way.
ChrisFix has a video on testing fuel pressure, maybe that is helpful:
1997 v70 T5 Stutter at WOT on T5
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
Okay, tested the fuel pressure today, seems fine to me.
Key on position 2 At idle Blipping the throttle while stationary
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
I believe at idle you should be at 43psi. So you might be on to a problem.
1999 V70 GLT
1999 V70 GLT
- misha
- Has thanked: 152 times
- Been thanked: 402 times
No,Sveedy...it have vacuum controlled FPR at fuel rail.
M4.4 with FPR at fuel filter have steady 43 psi all the time.
With FPR at fuel rail,fuel pressure changes at idle and at WOT...but on 1st prime it should be at 43 psi and at WOT.
At idle it should be around 35 psi because the vacuum controls it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1504 times
- Been thanked: 3817 times
Added year model to title
- Sveedy
So quick question: If I'm set up with M4.4 but have a FPR on the rail, what should my pressure be ? 35psi at idle ?
If so then I'm getting a little too much pressure myself.
Now back to Fiodor's problem...
1999 V70 GLT
1999 V70 GLT
- misha
Yes...if FPR is stock.
With factory setup,M4.4 cars have constant 43.5psi fuel pressure no matter if engine is idling or at WOT.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
