2000 V70XC Exhaust Manifold Lower support Topic is solved
Has thanked: 1847 times
Been thanked: 1710 times
Re: 2000 V70XC Exhaust Manifold Lower support
Piece of flat bar and 3 holes? Then move the bracket from the middle hole and move to the end of a longer piece and bolt it on the end. Drill 2 holes where the current block mount holes are and a 3rd to line up where the manifold mount needs to go.
volvoAgX
Year and Model: 2000, 2006 XC
Has thanked: 15 times
Post by volvoAgX »
Thanks Neil, that would work. I think I'm all set, I'll either make a new bracket or acquire a drop-in Japanifold. Not sure at the moment.
2006 XC70, 2000 V70XC, 2015 Honda Accord V6
volvoAgX
Post by volvoAgX »
Chuck W - if you're still following this, I would be interested in knowing what you did with this lower support bracket when you put the R-style manifold on your '96. Modify it? Omit it?
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 334 times
Post by Chuck W »
I didn't use it.
volvoAgX
Post by volvoAgX »
Thanks for the comments.
Jim
Good Luck Jim!
volvoAgX
Post by volvoAgX »
Thanks Neil. While the R-style manifold would have been fine, I now have a Japanifold in-hand and I'm going ahead with that.
