vacuum tree for seafoam access
Serge850T
Year and Model:
Post by Serge850T »
Hello,
Can anybody post a snap shot of the location of vacuum tree for seafoam access? Thanks.
Serge850T
Year and Model:
Post by Serge850T »
I found it already :D Did a seafoam thru one of the vacuum line with good results. Will do compression testing today.
GreenV850
Year and Model:
Post by GreenV850 »
Serge850T wrote:I found it already :D Did a seafoam thru one of the vacuum line with good results. Will do compression testing today.
Can you post a pic of what location did you use for the vacume t ?
Serge850T
Year and Model:
Post by Serge850T »
You can go to this site for details of the "vacuum tower" http://volvospeed.com/Repair/vacuum_lines.php
When you remove the throttle body cover you will be able to see either 3 capped or 1 capped vacuum line. You can use either ones not being used (capped) to attach your suction tube. Please see uploaded image...
