Heater hose replacement Non-OEM KINKY
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
I replaced the heater hoses on my 98 V70 some years ago using standard heater hose. Cut the ferrules off with a Dremel, and it worked great. Problem is that if you want to do this without kinking the hose you end up doing loopdidupes. Has anyone found a way to make a curve or a 90 degree bend in these hoses? I've thought of trying copper pipe fittings, maybe two 45 degree elbows.
Any clever ideas out there?
All U.S. market models.
All running and on the road.
Has thanked: 1846 times
Been thanked: 1710 times
How about a coil spring inside it?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
scot850 wrote: 21 May 2022, 17:29 How about a coil spring inside it?
I was looking for just such a thing a few days ago. I found purpose made springs for inside hose on Amazon. I think they were from Earl's. I did not end up making a purchase, as I decided to buy a formed hose for what I'm working on.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
The auto parts store may have an assortment of heater hoses with formed bends at lower cost than OEM hoses. I found a suitable formed hose for a 240 Volvo flame trap this way.
Eddystone
Post by Eddystone »
As usual, Robert has an answer. One option is the silicone hose do88 kit sold at IPD and FCP.
Been thanked: 471 times
Post by cn90 »
When I did this heater hose mod in 2015, I just used regular heater hose (Gates brand), the bend was not that bad and it worked fine the way it was modified...
See photo #6 in the thread below and you will see the curve is not that bad.
DIY: 1998 Volvo S70 GLT Heater Core, Heater Hoses Rebuild!
viewtopic.php?t=69238
Eddystone
Post by Eddystone »
cn90 wrote: 21 May 2022, 19:54 When I did this heater hose mod in 2015, I just used regular heater hose (Gates brand), the bend was not that bad and it worked fine the way it was modified...
I think it probably depends on exactly what brand of heater hose you get hold of. What I had was quite flexible, though I suspect it was Gates.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Dr. Abscate is working up this very solution, and I agree, it probably depends on the brand of the hose. That stone-age red stuff is too stiff the do anything but straight in.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
I bought the do88 hoses way back with another order and finally ended up using them last winter. I'd definitely get them if you buy something from do88 anyways. Very nice hoses and the old ones were really crunchy.
850 T5-R '95 auto Image
