So I started.
1. Battery- check it, check it again - It good.
2.Starter- new one.
3.Fuse and relay. check it.. It good.
3.5 Fuse on the battery- broken. So I brought a new one. Put it on. Nothing.
Check engine 163 021 008
4. Alternator -???
I had a stroke so ....
2011 Volvo S80 3.2 no start
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
I am not sure how much help I will be, but your codes seem to point towards a cam and/or throttle sensor issue, or worse so, a timing issue between the cam and crank shafts. My experience has been that it is the sensor going bad that leads to the fault. I am not sure if the throttle sensor can cause a non-start, but a cam sensor certainly will. Many on this site use the Vida, which is the gold standard, but personally I use an iCarsoft device I bought on Amazon for about $130. DTC codes only give you a glimpse of an issue especially on later models. Getting codes off the Volvo side of things will likely help in further diagnosing the issue.
Are you cranking and not starting
Or
Not cranking?
Or
Not cranking?
- 19 Replies
- 4660 Views
- 1740 Views
Last post by xHeart
- 695 Views
Last post by pgill
- 1180 Views
Last post by constants
- 3010 Views
Last post by RickHaleParker
