96 850 glt stalling issue
2forty
Year and Model: 850 1996
Post by 2forty »
My 96 850 glt is having issues stalling. The car will run fine for a few miles then begin to run rough then stall. I wait 15 minutes then drive it a few miles to home. I have replaced the MAF (reset the parameters) spark plugs, cap, rotor, wires, checked for emission leaks and replaced hoses. It happens most when the air conditioner is on. I checked my alternator and discovered that it was putting out 12.78 volts. I am going to replace it but could this really be my issue? Any thoughts?
Thanks
Has thanked: 2212 times
Been thanked: 1852 times
Have you swapped out the Fuel pump relay or checked fuel pressure?
Has thanked: 1611 times
Been thanked: 4075 times
You definitely have a dead alternator , or possibly a bad cable between alternator and battery. A weak battery can cause stalling
2forty
Post by 2forty »
Thanks for the responses! I checked my alternator, and it was putting out 12.5 volts. I am installing a new one and hopefully this will solve my problem.
Thanks again!!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Drive the car for 30min and let it idle,do not turn the engine off.
First check voltage output directly on alternator.
Positive probe on b+ and negative probe on alternator housing.
Compare voltage output on battery terminals.
If battery terminals are shoving lower output than alternator...then your positive battery cable is bad and needs to be replaced.
Healthy charging system produce 13.8-14.2v at idle with headlights,radio and heater blower ON at 1st or 2nd speed.
Perform a voltage drop test if needed on both...positive & negative side.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
