Exhaust Manifold removal Topic is solved
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
So is it easier, or necessary, to remove the turbo first before taking the exhaust manifold off, or can the whole thing be lifted out as a unit ?
1999 V70 GLT
1999 V70 GLT
- Has thanked: 1613 times
- Been thanked: 4078 times
I did down pipe first, then removed turbo from manifold.
Here
viewtopic.php?f=1&t=96254&hilit=Elizabeth&start=40
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
If you had a RHD, then you just sit back and cry. Drop subframe and remove from below, or drop subframe, remove brake booster, then remove from above. Many tears to be shed.
You lucky LHDrivers will find it easiest to leave turbo in place, on the downpipe, and just remove the mani from above. At least from what I've seen on Wheeler Dealers!
- Sveedy
Very cool
Thanks guys - I think I have the plan for Friday.
1999 V70 GLT
1999 V70 GLT
- Sveedy
Well I think I ended up removing the turbo first and then the manifold. It gave me a little more room to work.
1999 V70 GLT
1999 V70 GLT
- 15650 Views
Last post by erikv11
- 308 Replies
- 130302 Views
Last post by volvolugnut
- 18084 Views
- 691 Views
Last post by and1one1
- 15 Replies
- 3597 Views
