Exhaust Manifold removal Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So is it easier, or necessary, to remove the turbo first before taking the exhaust manifold off, or can the whole thing be lifted out as a unit ?
1999 V70 GLT
Has thanked: 1610 times
Been thanked: 4065 times
πŸ˜ƒπŸ˜ƒπŸ˜ƒ
I did down pipe first, then removed turbo from manifold.
Here
viewtopic.php?f=1&t=96254&hilit=Elizabeth&start=40
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
If you had a RHD, then you just sit back and cry. Drop subframe and remove from below, or drop subframe, remove brake booster, then remove from above. Many tears to be shed.
You lucky LHDrivers will find it easiest to leave turbo in place, on the downpipe, and just remove the mani from above. At least from what I've seen on Wheeler Dealers!
Sveedy
Post by Sveedy »
Very cool 8) Thanks guys - I think I have the plan for Friday.
1999 V70 GLT
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
How did this go?
I think I need to pull out the exhaust manifold on mine so I can properly install the studs and gaskets.
It's blowby
Sveedy
Post by Sveedy »
Well I think I ended up removing the turbo first and then the manifold. It gave me a little more room to work.
1999 V70 GLT
