What changes were incorporated w/ introduction of V70 facelift?
jrschwit
Year and Model: '01 V70 T5, '02 V70
Has thanked: 12 times
Been thanked: 8 times
Post by jrschwit »
Is there a post or reference which more or less completely documents the changes incorporated with the facelift o/a MY '05? My searches have not yielded any such compilation though I gather headlights changed from glass to plastic, taillight covers are different and the seat mounts are different, among other things.
My interest is because I bought an 04 V70 na knowing it needs some minor engine work. Come to find out it's most certainly MY 05 post-facelift (it does have plastic on the headlights, taillights covers are different and the seat mounts are distinctly different). It has a build date of 10/04 in Belgium, the serial number decodes to MY 05 and the owners manual shows 2005 but for some reason it is titled as 2004. I may soon reach a decision point whether to attempt repairs or make it a parts car for several 01-04 V70s that I am fixing up for the extended family. Having a better idea of what is or is not directly transferrable in the way of parts will help inform that decision.
Also. did the implementation of the all facelift changes occur at one time or were they made as supplies were exhausted? Similarly, did the implementation occur at the 04-05 MY break or at some other point?
Jim
Has thanked: 2197 times
Been thanked: 1851 times
It is titled 2004 as it may have been registered in 2004 although 2005 MY cars were starting to be sold as of August 1st 2004.
So plastic headlights covers, and diamond rear lights. When you look at the rear lights the silver part looks like diamond plate. -2004 had vertical lines in the plastic covers. You can swap them from one to the other. The MY 05 also have a little red LED strip marker on the outer side of the rear light lower covers.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Also, 05' model year has all trim painted in the color of the car, of course this doesn't apply to XC. Center console design was changed and the stereo systems re- designed. 04' was the last year with a cassette player. Interior trim went from gray to black/ charcoal. Rain sensing wiper design updated, in 05' it became an independent function.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Has thanked: 1609 times
Been thanked: 4064 times
Big electronics change in 2005 MY
The CANBUS was divided into two separate circuits , one low speed and one high speed.
jrschwit
Post by jrschwit »
Thanks for the info. From what you just shared and what I've gathered from other various posts, it appears the major changes were minor body and trim updates with a few electrical changes. I'm more interested in any significant powertrain and chassis changes which may not be immediately apparent and which would prevent swapping parts to earlier P2s. At this point, I don't have anything specific in mind but engine, transmission, suspension are potential candidates. Possibly also things like fuel pump and radiator, etc.
I'd also like to say what a valuable resource this site is. The willingness of so many to freely share their knowledge and experience is a very fine thing. Thanks to all.
Jim
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
abscate wrote: 01 Jan 2025, 07:44 Big electronics change in 2005 MY
All P2s have two separate CAN buses.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
2005 had an improved power steering fluid reservoir. Newer haldex awd if I recall correctly? What else ... PEM was added. CEM installation location was improved I believe due to water ingress. Spitballing here.. apologies .
04s60 2.4
04xc70 2.5t
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
vtl wrote: 01 Jan 2025, 11:52
Exactly, they always had a low and hi speed bus, the difference was their bitrate.
