DIY: 2007 Volvo S60 VVT Hub & Cam Seals x 4 (or any P2 XC90, S80 2.5T, and 2.4 engines)
- The issue of FRONT cam seals leak has been discussed too many times in different forums. After doing this job, you will understand why dealers charge $1000+ for this job, read on…
- I am working on a 2007 S60 2.5T with 115K miles, no cam leak yet but my 2005 XC90 2.5T with 125K miles (TB was done at 110K) is leaking from FRONT cam seals. Now I learn the lesson that at 110K-120K, if you ever do the TB job, replace the cam seals while there. But it is more complex than that, maybe the excessive play of the Exhaust VVT Hub contributes to the oil leak.
I am doing the TB on the 2007 S60, so I may as well replace the front cam seals (and rear cam seals) since I am there anyway.
- Before doing this job, remove the TB covers and run engine briefly to see if the TB walks in and out or not, just to get a baseline feeling of how things are. You may want to record a brief video for the purpose of comparison later. Some worn-out VVT Hubs make noise. This way after you installed the new VVT Hub and cam seals, you can compare the difference.
- There are 3 separate issues:
1. Oil seal brand and installation technique. I use Corteco.
2. VVT, especially after 120K, can move enough axially that even with new seal, it may leak if you are not careful with the seal installation (read on). At 115K miles, my VVT Hub has an axial play of 1.7 mm. Brand-new VVT Hub has a play of 1 mm. From reading different forums, by the time the VVT Hub play is 3 mm, there is a good chance it will leak, even with new cam seal. So, if you have more than 130K, you may as well replace the Exhaust VVT Hub, and hopefully you only do this job once.
3. VVT Hub indexing: with VIDA instructions close to worthless (1 cog, 1.5 cogs and all that blah blah blah), and most of youtube videos on Volvo VVT hubs show a lack of understanding of the engineering aspect of VVT. Many youtube videos are misleading and inaccurate, therefore I will attempt to consolidate all these issues in one DIY.
- Also, the pdf by @F250 is somewhat confusing (despite his nice attempt to write it). I personally ignored his pdf, I found it difficult to read and unnecessarily complicated.
- The way to understand the Volvo VVT Hub engineering design is to ignore VIDA bc VIDA instructions for the VVT system are so bad.
- In contrast to other car mfg’s that index the VVT Hubs, making installation a breeze, Volvo does not index (key) the VVT Hub. Instead, Volvo decided to use the T55 bolt and 88 ft*lb! No big deal. The T55 bolt is for “coarse adjustment”, and the 8-mm bolts oval slots are there for “fine adjustment”. Think this way: during operation, the rotating force goes from:
TB ---> Toothed Sprocket ---> 8-mm bolts (mated with Outer Hub) ---> turning it CW ---> Inner Hub (which is mated to camshaft via the T55 bolt)
- Let’s say during installation, the T55 bolt turns the hub a bit, maybe 2-3 mm past the mark, you can always do the “fine adjustment” via the 8-mm bolts. This is why you leave the 8-mm bolts in the middle of the oval slots, just in case you need to adjust it.
BEST is to install the VVT Hub about 2-3mm just to the left of the timing mark, slowly tighten the T55 bolt with the RH while the LH keeping the hub rotated to full CCW to counter the rotation. Rotate the Hub back and forth to verify timing mark between tightening sequence. During tightening, it will move a bit to be just about right. I found out after 25 ft*lb or so, the timing mark did not move any longer as I tightened the T55 bolt. Go slow in increments and do not tighten to 88 ft*lb until you are happy.
- Whatever you do, once said and done, you should rotate the VVT Hub back and forth CW and CCW; in full CW position: it must match with timing mark.
- Another way to understand the VVT Hub design is: The Toothed Gear is mated to the Outer Hub via the 8-mm bolts, and the camshaft is mated to the Inner Hub via the T55 bolt. The Outer Hub rotates CW and CCW. During engine operation without the VVT activated, the Blue dot lines up with the Red dot in my diagram below. When oil P is pushed inside, the piston inside the VVT Hub is pushed outward and thus translates the linear motion of the VVT piston into rotational movement of the Inner Hub, turning the camshaft CW to advance it. This is bc the VVT Toothed Gears and Crank
Sprocket have a fixed relationship dictated by the TB teeth. Think of the VVT Outer and Inner Hubs rotating w.r.t. each other.
If you think like an engineer, it will be clear: when you turn the Outer Hub full CCW (engine off w/o the TB installed), the camshaft is effectively in an advanced position. And that is for testing w/o the TB installed. Once the TB is installed, you cannot turn the Toothed Gear CCW, the only way to advance the cam is via the oil pressure feeding the VVT, turning the camshaft CW into the advanced position.
- You need to be familiar with the Volvo 2.5T TB job first. I wrote an extensive DIY on my 2005 XC90 2.5T here.
- If this is the first time you replace the cam seals and VVT, make sure you read through the TB DIY first.
If you are coming from P80 (1993-1998 850 and S70, V70), then this will be easy transition if you read a bit on VVT Hub engineering. Please note that I updated that DIY to route the TB during installation clockwise, it is much much easier that way…
---> DIY: 2005 Volvo XC90 2.5T Timing Belt, Water Pump, Serpentine Belt
viewtopic.php?t=83521
TOOLS:
- Serpentine Belt Tool is a must. It is inexpensive at Harbor Freight or ebay.
- The thin-profile levers (3/8” and 1/4") made the job much easier bc you don’t have to remove other parts to get to the rear cam seals etc. The Powerbuilt tool is a great helper.
- Metric wrenches, Torx set (for cam sensors) and Hex metric set (Hex for the TB tensioner).
- For the VVT Torx #55, I bought the 1/2" type. Forums told me 3/8” type T55 is also fine.
Since this is going to 88 ft*lb, I use 1/2” type. After I did the job, I also bought the 3/8” T55 socket, I should have bought this too. The difference of 6mm between the 3/8” and 1/2" socket makes a huge difference. The 3/8” T55 is good for the cap, and the 1/2" T55 is good for the big center bolt. Or you can buy just the 3/8” T55 for the entire job.
- FYI…A 1/4" drive can take about 30 ft-lb, 3/8" about 100 ft-lbs, 1/2" about 230 ft-lb in normal operation. The 3/8” drive breaks about 150 ft-lbs, 1/2" about 300 ft-lb.
- You need the 1/2" 30-mm socket + long extension to spin the crank gear.
- Liquid Paper, Sharpie pen to mark VVT hubs.
- PVC couplers, some plumbing adapters (read on), mirror to see better.
- Of course, you need the floor jack and jack stands (please see the DIY XC90 2.5T TB for detail of jack points).
- Cam locking tool: search forum for home-made stuff, but my advice is to use the CTA tool ($110) bc it seems better than EWK ($50). By using CTA tool, less risk of damage. You can always sell the CTA tool later on ebay once done or if you no longer own the P2 cars.
PARTS:
- Good source is FCPEuro etc. I bought most of my parts from FCP. The Exhaust VVT Hub was on sale Ft Washington, PA Volvo dealer for $215 with free shipping.
- Cam seals: the FRONT cam seal is definitely Corteco. When placed side by side, the Volvo factory seal is identical to the Corteco (Corteco ground off some numbering system on the seal surface to avoid issues with Volvo). The REAR cam seal: I do not know who made it for Volvo, but my experience using Corteco for the rear cam seals has been excellent.
- TB Kit: I have been using Continental for yrs. Conti is the orig mfg for Volvo TB. Inside the Conti TB kit is INA pulleys.
- Serpentine belt: I use INA pulley and Conti belt. The 2007 S60 uses a shorter belt than let’s say 2004 model (smaller PS Pump pulley diameter in the 2007 S60).
- At 115K, the Intake VVT is still good with minimal play. The Exhaust VVT was still OK with about 1.7 mm radial play (no oil leak at 115K yet) but since this is such a big job with tons of potential issues, I elected to install a new VVT Hub bc I don’t want to do this job again.
PROCEDURE:
I must say after doing this job, the car runs fine, probably more acceleration bc of the new VVT (maybe it is all in my head lol). No oil leak.
I leave the TB covers off for a week while checking for oil leak. So far so good. Before VVT Hub job, the TB “walks” 0.3 mm in and out during engine operation, still within spec @ 115K miles. After the new Exhaust VVT Hub: zero walking of the TB, perfectly straight during engine operation!
After the VVT job, car threw a code P0026 (Intake Solenoid) presumably from not enough oil pressure building up after the job. I erased the code P0026, never came back. So if you do this job and have the P0026 or P0027, just relax a bit and erase the codes to see if they come back.
The thing about this job is during installation, go slow and be methodical, do NOT torque anything to specifications until you are happy with the VVT indexing. For example, the 8-mm bolts: just snug them to about 4 ft*lb instead of 8 ft*lb. Only after you are happy, then go to 8 ft*lb. Same is true for the big T55 center bolt, go to ~ 25 ft*lb, which is enough for testing the VVT Hub CW and CCW. Then go to 40-50 ft*lb and check again. Only after you are happy, then go to 88 ft*lb. I found out after ~ 25 ft*lb, the VVT Hub index mark does not rotate any longer as I tightened it further.
1. Parts as shown, serp belt tool, and thin-profile levers (3/8” and 1/4"), CTA Cam Locking Tool:
2. PVC Couplers etc. with Cam Seal. Note old hub with 115K (no oil leak) has a groove from millions of rotations with the sealing edge of the seal creating a groove. If you re-use the old hub (i.e. budget issue), then make absolutely sure the new seal sits exactly as factory, more later.
3. Use Permatex Black RTV around the OUTER edge of the seal, so it has less chance of coming loose.
Wet the inner lip of the seal with oil when inserting the new VVT Hub. Permatex Black RTV package says it takes 24h to cure. So best is to do this job on let’s say Saturday but don’t start the engine until Sunday.
4. The VVT Hub 8-mm bolts is M6 x 1.0 type. Torque is 8 ft*lb. I use Red Loctite. When transferring the
Tooth Sprocket to the new VVT Hub, just use the factory setting to start where to place the 8-mm bolts.
If you ever strip the threads, either on the bolt or the VVT Hub, do not panic, just get a small M6 x 1.0 nut and install it with Red Loctite. I did not touch the Intake VVT but no idea why Volvo designates a different torque for Intake VVT (maybe 10-12 ft*lb).
5. Timing Belt, Serp belt and Pulleys.
6. Engine photo so you can see where the bolts are. Note that I use the minimalist approach: unclip the Air Filter Cover and loosen the clamp as shown, this allows you to move the big plastic tube (removing this big plastic tube is a pain, so I avoided it) sideways, then tie it with a string to keep it away. This way you can use the thin Powerbuilt tool. I guess the serp belt tool works here too bc it has a low profile.
NOTE: the Intake Cam Sensor holes where the bolts go, I missed this part and inserted the bolt in the wrong hole on the top lol. Took 15 min to find out where it should go…
7. Once the cam sensors are off, use 10-mm socket to remove the Reluctors. This is why you leave the TB alone until now to avoid moving the camshaft.
NOTE: Intake vs Exhaust Reluctors are different, label them to be sure but it is not necessary bc if you look in the back of the Reluctor, they have different indexing tabs.
NOTE: the force of removal will break the tiny little tab on the end of the Intake camshaft. No consequence here at all bc the Reluctor will reinstall just fine (install this bolt ONLY after TB is re-installed). However, you might want to insert a tiny woodruff key in that space to avoid the damage to the little tab. I use Red Loctire during installation.
- CTA tool came with no washers, I used some washers on the bolts. TRICK: when rotating crank to get to timing mark, stop the crank about 1 inch before the timing mark, then moved it very very slowly 1-2 mm at a time while checking the rear to see if the Locking Tool fits, just snug them loose and slowly tighten them.
Only when you are happy with the setup, then tighten the bolts, I just snug them then tighten a bit, no need for excessive force, I am guessing 12-14 ft*lb.
8. Once the rear side is good (Cam Locking Tool in place), go to the front, the CRANK long mark (use the long mark on the crank, much easier to see than the tiny marks) should line up, as well as the VVT Hubs.
If you look at the DIY TB I wrote in the link, I marked behind the VVT Sprockets (on the engine side), it made it much easier w/o the need to re-install the TB cover to verify timing marks.
NOTE: During installation, I used the Clockwise approach to route the TB, it is much easier this way bc the TB keeps the VVT Hubs in full CW direction. Just follow the sequence in the Orange color: 1-2-3-4-5-6, i.e., the TB slides on the Idler Pulley last. Don’t forget to tighten the Tensioner Pulley (using the 6-mm hex key to adjust at the same time), the tensioner pulley is such a critical bolt, I used Red Loctite here.
Routing the TB CCW way is cumbersome and wasting time, I found out CW is better after 1h fighting with the TB doing the CCW way!
9. To disconnect the coolant level sensor connector, there is a tiny tab, use the small flat screwdriver to gently loosen it. To prevent fluid loss, cut a “finger” off the rubber glove + rubber band as shown. I also used some cardboard as cushion to prevent the Sprocket from rubbing the hoses (coolant and PS hoses).
10. Space was tight, so a 10-mm wrench may help. Or use serp belt tool. Since I did not have the 3/8” T55 socket, I had to use this setup lol… In retrospect, I should have bought the 3/8” T55 socket.
TRICK: use a zip loc bag underneath to catch the oil leaking out.
11. Tie the coolant reservoir away. Note I had to use an iron pipe to undo the T55 bolt. This is when you will likely break the small little tab on the end of the camshaft on the rear side. See note above.
12. The seal exact spot was discussed in the thread link below. This is a must-read if you don’t want to do this job twice! Note that the factory design was poor: the bore side of engine was a little loose and the Corteco seal can be installed just by hand and it has a tendency to fall off with time (search forum, there are tons of threads on this), I used Permatex Black RTV as mentioned above.
Cause of intake cam seal leak?
viewtopic.php?t=82864&start=10
13. Here is the factory setup, note the cam seal sits at the very edge of the chamfered edge. I used the PVC Coupler + Sharpie mark, it makes installation check very easy, you are talking 0.5 mm here and there! When you install the VVT Hub, oil the outer shaft first, you will hear a distinct “pop” when the VVT Hub is fully inserted: this is the sound of the sealing edge popping back onto the VVT Hub shaft.
14. If you ever push the seal too far in, such as 1 mm too deep, no worry, use a pair of right-angle pliers to gently pull it back out. Note I use a small piece of cardboard as cushion on the camshaft sides.
15. The REAR cam seal: as mentioned many times in forum, I used a small punch, then inserted a screw dead center to remove it. Do NOT damage the shaft side! I happened to have a plumbing adaptor as shown, this device was perfect for installation in the tight space!
16. For Front Cam Seals, the Engine Bore depth is 7 mm, Seal size is 51 x 65 x 7mm. You can see the old seal is getting tired with sealing edge being dull. The new sealing edge is sharp…
17. Brand-new Exhaust VVT Hub moves in and out axially 1 mm between CCW (cam advanced) and CW (cam retarded). Note the Range of Movements of Exhaust vs Intake VVT Hubs in terms of degrees.
My guess re wear and tear is that: the Exhaust VVT is activated more frequently, thus the wear at 115K.
The Intake VVT probably does very little work during engine operation, thus almost no wear at 115K miles. I do not have the engineering spec’s of angular rotations of Intake vs Exhaust VVT Hubs, but the photos showed what I found…
18. Some photos of the cutaway view so you can see the way oil flows through the VVT pushing the piston outward, in the process of doing so, the INNER gear is rotated CW, thus advancing the cam.
The cutaway view is courtesy of @jimmy57:
Thank you for reading this. You will be happy with new Exhaust VVT Hub and Cam Seal.
Of course, double-check, triple check all nuts/bolts and manually rotate the engine crankshaft x2 using the 30-mm socket before starting the engine.
When in doubt, check again before firing up the engine!
Once you are happy with everything, say a quick prayers and fire up the engine…
PS: “Enjoy” this Volvo job while it lasts, newer engines use timing chain and there is none of this non-sense. All this happens bc of the timing belt design inherent in older Volvos, Hondas, Toyotas etc. My 2004 BMW 325i M54 engine runs on timing chain, which is concealed and timing chain lasts some 300K; also there is no such thing as BMW cam seal bc the timing chain is inside a cover and bathed in oil. The BMW Vanos does not ride on a cam seal. Overall, the BMW design for VVT (Vanos in BMW) is superior, from an engineering standpoint. Anyway, TB design is the yesteryear stuff, soon or later, it is going the dinosaur way, so “enjoy” this job while it lasts lol…
DIY VVT Hub & Cam Seals on P2 Models
- Been thanked: 504 times
- Volvo-VVT-03.jpg (148.28 KiB) Viewed 21067 times
- Volvo-VVT-04.jpg (74.3 KiB) Viewed 21067 times
- Has thanked: 311 times
- Been thanked: 818 times
This is a masterpiece, thank you cn90!
Anyone have experience with how to avoid breaking the tab on the rear of the camshaft; would it help to crack that bolt loose before removing the timing belt?
I'm hesitant to replace cam seals and VVT hubs preventively because on my P2 cars they are still bone dry at mileages of 190k (07 XC70) and 172k (06 S60). At the 200k timing belt changes I'll have to decide if fit's worth the extra labor savings or if I want to continue waiting for signs of trouble. Checking the axial play on the hub as described here will factor in to the decision, good info.
Regarding my comments above, this summer I needed to do a timing belt on our green 07 XC70 with 200k. Here are some notes from that experience to supplement:
1. Replace the bolts in the cam locking tool before you use the tool. The bolts that shipped with mine were junk metal.
2. The locking tab(s) did not break off the cam, just go about the job carefully you should be fine.
3. I didn't use any loctite
4. None of the cam seals were leaking and I didn't have a lot of time so I didn't touch them; I left all four cam seals in, front and rear. They are the original factory seals. If I get a leak I'll go back in for it later.
5. The exhaust VVT hub was wobbling so I replaced it. Intake cam hub was fine so I left it.
- Has thanked: 1611 times
- Been thanked: 4072 times
That little cutout on the cams labeled “ woodruff key” is left over from the -1998 models and is used to index the distributor rotor, no longer used on our 1999- cars
Is there any reason the hub shaft could not have been made a tiny bit longer? The seal rides so close to the end that there is hardly any room for axial play at all! This must have been designed by the same people that put the critical part of the PCV system under the intake manifold. The exhaust hub seal was a fairly tight fit on my block, I set it not quite inside the chamfered edge hoping that the silicone will help secure it. It took a 4' section of steel channel on the Torx bit to break it loose, bending two wrenches in the process. But it gives me a new appreciation of Torx bits: as I leaned on the lever, I could just imagine stripping out the bold leaving me with a total disaster, but once it was out, I could see no damage to the bolt at all! (Just noticed that the Craftsman wrench was one that I had ground down a bit to access fan bolts on a 240!) At any rate, many many thanks for all of this information, I am in awe of the expertise here!
@mbliss et al,
The factory cam seal is 51 x 65 x 7mm (please verify).
As mileage adds up, the Exhaust VVT develops play and it can slide in and out (when advancing or retarding the cam shaft) of the seal, causing oil leak.
Instead of changing the Exhaust VVT Hub, which currently costs some $380-$400, I just came up with this idea that I have not tried yet: using a deeper seal to bring the seal lip (where the garter spring is located) out another 2 mm to the region that is 2 mm from the deep grove shown above, by using maybe 51 x 65 x 9mm or 51 x 65 x 10mm?
If anyone ever tries a deeper seal (and thus reusing the VVT Hub), please post your experience. If this idea works, ppl save a lot of money.
This is an update on the 2005 XC90 2.5T with 132K miles.
This oil leak: I have been watching it for 4-5 years.
Finally had a nice weekend to replace the Exhaust VVT Hub.
The procedure is virtually identical as the S60.
1. The usual places of oil leak:
2. The idea of Woodruff key or wooden chopstick is fine but the small little tab on the cam still broke later.
So, no need to protect this little tab. It is inconsequential.
3. Exhaust vs Intake VVT at 132K miles.
- Exhaust VVT play: 3.0 mm ---> replaced with new INA unit.
- Intake VVT play: 0.7 mm ---> re-used without issue.
4. The Front cam seal: after making the installation tool using wood, installation is 5 seconds.
The Corteco seal simply pushes in, no hammer needed!
This is why I used black RTV just to be sure and let it sit for 24h.
5. REAR cam seal: the 32-mm socket + bolt makes it very very easy, just go slow and check to be sure the seal just sits
at the chamfered edge.
Do one seal at a time so you can use the other seal as a reference to see how deep you should install the new seal.
PS: If you don't have VIDA or a code reader and don't want to see the code P0026 (Intake Solenoid)?
The book says after timing belt job, turn the crank 2 full 360-degree revolutions. Well, if you turn it 6-8 revolutions, it should be enough to prime the VVT Hub with engine oil: this was what I did this time: no CEL at all.
Also to answer @mbliss question...
If you look at the seal (51x65x7 mm deep), the sealing lip (with garter spring) rides about 2 mm from the edge
of the VVT Hub. Also, the flat part of the inner lip of the seal is ~ 2 mm from the housing. So, during operation,
the VVT Hub edge is about 2 mm from the housing, and thus cannot be made longer for obvious reason.
This is a standard photo from the internet that I sketched (not to scale) to show the issue. So, the very inner edge
of the VVT Outer Hub sits flushed with the seal's inner lip, thus the sealing lip (with garter spring) normally rides
about 2 mm from the very edge of the VVT Outer Hub.
Anyway, I have come to the conclusion that in order to save money on the new Exhaust VVT Hub, if you decide
to re-use the Exhaust VVT Hub with some play, options are:
1. Use a deeper seal as mentioned, maybe 51 x 65 x 9mm or 51 x 65 x 10mm?
Question: where to find these?
2. Install the Corteco seal backwards with the garter spring facing outside (this is my new untested idea). Just apply
some grease on the garter spring to keep it in place and to keep it moist, but this area is protected by the TB cover
anyway. The idea is: by installing it backwards, you bring the actual sealing lip (with garter spring) about 4 mm
further out. Now the "dust lip" faces engine oil instead of outside air, this is no big deal. What is important is actual
location of the sealing lip w.r.t. the VVT Hub rotating shaft.
Anyway, if anyone ever tries either option #1 or #2, please post your experience...
- Has thanked: 987 times
- Been thanked: 1078 times
I am a bit confused on the normal rotation of the exhaust VVT on 2001 V70 T5. This has the spring loaded VVT on the exhaust shaft only.
I am replacing front side cam shaft seals and have a question about the range of rotation on the VVT. I can smoothly rotate the VVT hub in the CW direction against the spring. Should there be any rotation CCW from the spring relief (no tension) position? I have no CCW rotation on my hub, but some notes seem to imply the hub should have CCW rotation from no tension position.
I posted this question in new post and got an answer. See viewtopic.php?t=107662
There is no rotation CCW from the spring relaxed state.
For Your Information Tip
A 30 mm open end wrench can reach down from the top to turn the crank nut. The wrench does not fully engage the nut, but is ok for slow turning. It will not be suitable for tightening or loosening. There is limited room for turning - maybe 30 degrees. But easier than removing wheel and inner fender for crank access for socket just to turn the engine over.
