2007 S60 2.5T Radiator Replacement
Been thanked: 504 times
Post by cn90 »
I posted the photo in this thread...
viewtopic.php?t=88976
Has thanked: 312 times
Been thanked: 818 times
Which radiator did you buy? I've got a leaky hose neck on the 06 S60 radiator; it's probably cracked.
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
MoVolvos wrote: 11 Feb 2026, 20:14
jonesg wrote: 11 Feb 2026, 12:52 on turbos , remove bottom front air dam, elec cooling fan, drop the rad and intercooler together from the bottom.
Go back in the same way, a milk crate and blocks of wood will hold it up until you can get it fixed from the top.
Make sure you have new Oring seals for trans lines and new clips for those lines. FCP.
I have some clips and rings sitting around some place intended for another car. The crate is a good idea even though I'm going to attempt removal from the top, thanks.
I wrangled mine out the top but damn if I could get it back in the same way, gave up and dropped the IC, both go back together,
good opportunity to give the IC a draining out.
After wrestling with it for hours I looked at vida and it says out the bottom in a pair, duh.
jonesg
Post by jonesg »
erikv11 wrote: 12 Feb 2026, 09:58 Which radiator did you buy? I've got a leaky hose neck on the 06 S60 radiator; it's probably cracked.
FCP nissan, approx $255.73
MoVolvos
Been thanked: 525 times
Post by MoVolvos »
volvolugnut wrote: 12 Feb 2026, 07:31
MoVolvos wrote: 11 Feb 2026, 20:11
volvolugnut wrote: 11 Feb 2026, 08:06 I replaced my 2001 V70 radiator from the top. Details reported here
viewtopic.php?p=484005&hilit=radiator+t ... ce#p484005
No photos were included.
I don't know which is easier - top or bottom. I did from the top because I do not like laying on the ground working above.
I was think about lifting out the radiator by itself but didn't see how to separate it in the car as everyone removed the Rad and IC as one unit. I don't have access to level ground right now so prefer not to go under the car. In your link you removed this brace "The steel cross brace has many bolts , but these are easy to remove and the brace lifts off. ". I've watched many videos but am not sure if anyone had dealt with this brace?
I may have been first to try this method of removing from the top. I did not like the idea of raising the car enough to take the radiator out the bottom so started removing things until it came out the top.
The cross brace is the black steel formed plate between the bumper and the radiator. This is the part that always becomes the tool tray when I work on the engine.
Is that the brace? From your link and "reverend" photo.
Front End.png (639.59 KiB) Viewed 825 times
MoVolvos
Post by MoVolvos »
cn90 wrote: 12 Feb 2026, 08:39 I posted the photo in this thread...
1) Is that part a Filter Dryer or Accumulator?
2) Can it be separated so it stays in the car rather than attached to the IC as it comes out with radiator?
3) For some reason from the videos I watched I thought those 4 long bolts was attached to the Condensor?
4) If the 4 bolts are attached to the IC then it can be removed after taking both units out as one? In some videos they were removed while in the car.
Accumulator Or Filter Dryer.png (1.14 MiB) Viewed 823 times
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
MoVolvos wrote: 12 Feb 2026, 23:33
Yes, that is the brace to be removed. Multiple screws on top to remove. A few plastic rivets also.
ADent
Year and Model: 2001 V70 T5M
Been thanked: 5 times
Post by ADent »
I did not have to break the A/C system when I replaced mine.
It went in and out the top. IIRC (it's been awhile), remove fan, undo all the bolts and get the radiator out (tilt back a bit and work it out).
If you look at the V70 video posted above there is several inches of clearance behind the radiator - don't see why it couldn't come out the top with the intercooler left behind. Might be easier to take the two, but I don't think I took the I/C out.
2001 V70 T5M
1988 740 GLE 5.0
MoVolvos
Post by MoVolvos »
ADent wrote: 26 Feb 2026, 00:17 I did not have to break the A/C system when I replaced mine.
Glad you posted. Saw a video, too many now but one had a removal from top without IC. Will see how well that works when the time comes.
