Recurring P0101
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
Whoa, now we're getting somewhere. Sounds like I might need to take it somewhere to have the preload set properly.
Has thanked: 1611 times
Been thanked: 4075 times
Just replace the hose first. It’s the fatter one that runs to the intake manifold that pulls the turbo off, not the thin one going to the turbo control valve.
hu5ker555
Post by hu5ker555 »
I replaced the snorkel and hoses today. Smoke seems to be coming from the base of the wastegate actuator.
Seem like you can get a new wastegate actuator for about $100. Remove heat shields, remove pin and disconnect actuator arm, remove two bolts holding the actuator onto the turbo unit, and pull off the little rubber hose. Sound about right?
hu5ker555
Post by hu5ker555 »
Ordered a new wastegate actuator from turbochargerpros for about $50. I'm pretty sure I've been running with minimal (if any) turbo boost for a while now. Hoping this failed diaphragm fix will restore turbo function. I don't have a good setup for resetting the wastegate preload. Was actually going to get a cheap sphygmomanometer with bulb (similar to a blood pressure cuff) but it only reads up to 6 psi (300 mm/Hg shown below). Maybe that is good enough, as I've heard factory value is 4.5-6 psi. Other pressure gages run up to several hundred psi and there's no way to be able to dial it in to low ranges effectively.
wastegate actuator
wastegate actuator
Screenshot 2026-03-09 090840.png (159.66 KiB) Viewed 2323 times
sphygmomanometer
sphygmomanometer
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
hu5ker555 wrote: 06 Mar 2026, 18:58 Whoa, now we're getting somewhere. Sounds like I might need to take it somewhere to have the preload set properly.
its very simple, actuator rod has a threaded clevis that fits over the wastegate pin, you adjust it so it holds the gate closed with engine off, just slight tension to prevent the gate from rattling around.
The spring in the actuator diaphram is what holds the wastegate closed, you have to pull the actuator rod out slightly to put it under slight tension and pop it over the pin, then make sure its snug, doesn't rattle, if good... insert the hairclip to retain the clevis on the pin.
lots of youtube videos for this.
jonesg
Post by jonesg »
Make the wastegate clevis 1/8 inch short of reaching the gate actuator pin..., pull the actuator rod out and slip it on, done.
The slight tension holds it closed as it builds boost, until the ECM tells it to blow off excess pressure.
hu5ker555
Post by hu5ker555 »
Man, I sure hope this cures my ills. Sounds like there's a good chance.
hu5ker555
Post by hu5ker555 »
Well crap. So I replaced the wastegate actuator. Runs about the same. Still stumbles a bit when accelerating at highway speeds. P0101 came back. Still doesn't feel like the turbo is really kicking in either. Will try a new TCV next. Fairly cheap and easy replacement.
And then while putting it through its paces yesterday, I now have a periodic misfire. Cylinder 2. I just had all the plugs replaced so guessing my hard driving/accelerating may have damaged the coil pack. Ugh.
jonesg
Post by jonesg »
vida can count misfires live if you have it.
hu5ker555
Post by hu5ker555 »
Replaced coil pack on cylinder #2. Seems better. Also replaced TCV. Gonna see how this goes.
